Over the last year I constructed a VAWT saronius rotor with the hope of improving efficiency with slight design changes. I constructed it completely with sweet equity and scrap metal from my workplace with the exception of bearings, paint and wire to this point. The rotor is made of oil barrels cut in half. I started using jig saw blades but ended up using a plasma cutter to save time. I also cut away all but ~3/4" of the barrel ends because I have no center shaft. I did this because what written stuff I have seen points to lower Cp because having a shaft blocks the airflow through the center. I used 4 stages of 2 barrels halves to maintain suggested configurations of a Dr. Modi.They are set at 45 degree offsets. The dividers and made of ~20 gauge ss cut out with a plasma cutter. I read that the dividers should be 5% larger then the laid out barrels which was ~44" with an 8" overlap in center for air flow. In the building process I decided to cut the trailing ~6.5" of barrel which I bent to give a more aerodynamic shape. At this point I welded my first 2 sections which I then realized spanned the whole divider since I had now stretched it out some. The next 3 dividers were then resized 5% larger then the original 2 dividers. ( Obtaining scrap stuff is kind of like sharks in the water...hit or miss...who ever gets there first.) The effect of this is to have 3 larger top sections dividers.This slightly tapers the bottom section down. The bottom/top dividers have bearing mount plates installed. The top for a good feeling sedan spindle/bearing and the bottom for a 95 grand am drive spindle/bearing . I then cut the drive shaft off with cut off wheels so I could insert the splined shaft through the spindle bearing which goes through the plate for my electrical rotor attachment. I made templates for the bearing plates by taping out the splined lug nut studs for accurate transfer punching. I later
reinserted the studs when it was time to attach it to the mounted bearings in the tower. I then welded and drilled out the end dividers . The tower is 21' pallet racks, 5' of which is in the ground with welded piped cris crossing in all directions for support. One side is slightly lower which has caused me to shim the bearing mounts so that they were level. The completed rotor was just under 12' long and ~44" wide.
After mounting the rotor I let her freewheel. To my horror (and delight to know it turned) in a ~15 MPH wind, it freewheeled apparently out of control and bent in the middle sending periodic sparks in the darkness in faster gusts of wind. The center stage divider had worn a ½" slot in the tower by the time I stopped the rotor. I then locked it down and over the course of a couple of months added 4 - 1x1 square stock bars to give it support. I did the best I could to balance it by welding on pieces of stainless flat stock. Usually I leave it locked down but on some days with
winds below expected 20 MPH winds I let it freewheel but in general do let it exceed ~210 RPM at (~20 MPH) which time it starts to cause tower vibrations. I left 2 sides open for more free air but I think I am going to add at least 4 more cross pieces to strengthen the tower and cut vibration hopefully at faster speeds.
My company uses magnet canisters in its food safety program and when they don't reach a certain pull test they are discarded. Guess what they are...Neo(S) abet on the small size. My electrical rotor plate is just over 23" in diameter of ½" thick steel cold rolled plating and I am using 40 discarded 15/16" dia by 7/8" high neos. I have 17 others of the same size. I also have a few dozen more of larger and small sized neos. I have tinkered with only 3 coil designs. One was with lengthwise coils which didn't work to well. Then I tried a spool which did a little better and then I
did a round coil which is the best so far. I am testing 21 gauge wire starting with an ID of 3/4" out to over an inch. 68 ohms of wire. I developed an unacceptable 1.25 Volts ac @100 rpm on 1 coil but I can obviously increase my turns to get more voltage and improve the shape. I can also make an extension and have a dual rotor which I am leaning towards. ........so here goes the questions :
- ) Coil spacing should be the size of the magnet. What kind of problems can be made by squeezing in a few more coils or overlapping coils ?
- ) Do I have to keep the magnet spacing the same diameter as the magnets or can I take extra neos and squeeze them into the circle or does cancellation negate any benefits ?
- ) How much would I lose if instead of a dual rotor I doubled up on my magnets on the single rotor and put laminations on the stator ?
- ) Would it be economically worth it to scrap my smaller neos and install larger ones.
- ) Any other comments to help me pull as much out of this project as possible. It may me that it will just be a property ornament and staging for a Darius Experiment or HAWT on top of the tower. My neighbor asks "what's that twirlly thing in your field ? "
Jim from Vermont
252 Scoop users have viewed this posting.
