| Hi Members,
In winding coil using two wires in hand, do I have to be careful to layer both the wires parallel at each wind and make sure they stay together? I am having problem getting the two wires to stay together esp as I go from one layer to the next. Sometimes they separate as I turn even on the same layer going from right to left or going left to right.
What kind of wax do I use to prevent the coil from sticking to the jig after I apply the super glue to hold them on completion?
Sean.
Editors Note:
Sean;
This stuff has all been covered several times in the past and you really might consider doing a little reading looking for the previously posted methods. We are leaving this story posted in the interest of revisiting the subject. Google search the board will give pretty good results for searching the previous posts.
You might want to read This to understand the how and why of what does and does not make it past the editors.
92 Scoop users have viewed this posting.
