ggs theary by gorlov ? + aoa for darius rotors?
By electrondady1, Section Wind
Posted on Sun Jul 3rd, 2005 at 01:17:25 PM MST
has any one a link to this data?
ggs theary by gorlov ? + aoa for darius rotors? | 15 comments (15 topical, 0 editorial)
Re: ggs theary by gorlov ? + aoa for darius rotors (3.00 / 0) (#1)
by hvirtane (hannu_markus_virtanen(at)yahoo(dot)com) on Sun Jul 3rd, 2005 at 09:57:41 AM MST
Please see:
http://mystic.math.neu.edu/gorban/Gorlov2001.pdf
http://www.mos.org/cst/article/2806/1.html
http://www.recipeland.com/encyclopaedia/index.php/Wind_generator
Re: ggs theary by gorlov ? + aoa for darius rotors (3.00 / 0) (#2)
by electrondady1 on Sun Jul 3rd, 2005 at 10:45:39 AM MST
hello hannu, thanks, there is a lot of reading there.i have been spoiled by drag type mills i attempted to make a gorlov turbine by cutting spiral sections from a 20 litre paint bucket. it doesn't work. the rotor profiles will need to be alot more sophisticated.
Re: Gorlov performance research quote (3.00 / 0) (#3)
by aogden (abogden@sbcglobal.net) on Sun Jul 3rd, 2005 at 11:48:17 AM MST
Interesting research quote from http://mystic.math.neu.edu/gorban/Gorlov2001.pdf
" Conclusions
1 Despite only a narrow class ~1-parameter family! of the flows
has been considered for optimization, the result obtained allows us
to conjecture that the efficiency is maximal when the resistance is
rather small and a large part of the flow ~61 percent! goes through.
In other words, the maximum efficiency could not be noticeably
greater than what was obtained here.
2 The model of a free-flow turbine reveals a new class of problems
about streamlining with partial penetrating through an obstacle;
some of these problems could admit explicit solutions and
could have other applications.
3 The velocity of a flow vanishes at the origin of the proposed
plane model. This makes the model specifically applicable for
two-dimensional propeller-type turbines in free ~nonducted! currents.
The theoretical limit of the efficiency given by the model is
30.1 percent. A number of tests, as well as constructed power
farms, support this thesis in regard to both hydraulic and wind
applications. The efficiency of most water and wind propellers in
free flows usually ranges from 10 to 20 percent. On the other
hand, the three-dimensional hydraulic helical turbine develops an
efficiency of about 35 percent in similar free flow conditions @2#.
This high efficiency might be explained by modeling a 3-D rotor
as a combination of two plane turbines that reflect power contributions
from the front and back parts of the original cross-flow
turbine."
What I find significant is the "35%" efficiency claims for the Gorlov design.
Also here is a commercial wind power helical reference: http://www.turby.nl/downloads/Turby%20ENG.pdf
I have been trying to come up with common materials that could be adapted to make an efficient home sized helical Gorlov wind turbine however with little sucess.  Comments are welcome!
Re: Gorlov performance research quote (3.00 / 0) (#4)
by hvirtane (hannu_markus_virtanen(at)yahoo(dot)com) on Sun Jul 3rd, 2005 at 03:21:42 PM MST
I think that it is possible
to use wood for the blades
and also metal
tubes with wood air foil
pieces. Please see:
http://www.fieldlines.com/story/2004/11/29/10155/497
Also it could be possible to start
with a drum and to cut it open
a suitable way and to build up
'the blades' with some material
for airfoils?
Re: Gorlov performance research quote (3.00 / 0) (#5)
by electrondady1 on Sun Jul 3rd, 2005 at 08:40:28 PM MST
 my understanding of the creation of lift is that when the air is split by the rotor the surface on the top or in this case the out side of the is forced to travel a greater distance. the air is required to travel faster and and in so doing the air pressure is reduced.  the rotor is pulled forward.
Re: ggs theary by gorlov ? + aoa for darius rotors (3.00 / 0) (#6)
by hvirtane (hannu_markus_virtanen(at)yahoo(dot)com) on Mon Jul 4th, 2005 at 06:16:38 PM MST
here are some ideas
how to make a 'gorlov type' turbine.
The first pictures illustrate
the idea that the blades
are made using metal or plastic tubes.
Airfoil shapes are formed
by covering the tubes with cloth.
If tubes cannot be bent, the airfoil sections will
be longer on the ends of the turbine wheel.
But if the tubes can be bent easily it might
be better to bend them to follow the same
outer circle all the way from one end to one end.
The second construction starts with a drum.
The drum is cut open so that only three
rather narrow 'strips' are left from the surface.
These strips will work as the blades of
turbine.
There are in the picture two ideas,
how to make airfoil shapes of the strips.
With the first construction the other ends
of the strips are bent piecemeal. The result
is a J-shaped airfoil, quite similar
as with 'Lenz' turbine.
(www.windstuffnow.com)
With the second construction
in this picture
a metal or plastic tube is fitted
on the leading edge
of the blade strip.
Then the outer side of the blade
is covered with cloth.
I think that the air pressures
will form the airfoils perfectly...
Re: ggs theary by gorlov ? + aoa for darius rotors (3.00 / 0) (#7)
by electrondady1 on Tue Jul 5th, 2005 at 06:11:55 AM MST
those are good illustrations hannu. two things i noticed with my 20 litre bucket experiment, first,  the whole thing remained quite rigid inspite of having 50% of its surface removed. second , the object looked very pleasing to the eye when it was rotating. i experimented by cutting a slit in some plastic tubing and pushing that onto the leading edge. it responded better but my next step will be to apply the tubing to the out side edge as you have depicted. what are your thoughts on solidity as a percentage? the airfoil profiles you have drawn look "right".  this is where the real science is required , to produce the opptimun ratio between vain thick ness and vain width.  you are considering using cloth as a surface, to allow the airfoil to form itself?  consider this, if the sections of the surface removed to form the rotors (waste)were reapplyed along with the tubing over the remaining sections it would create a profile similar to that which you have drawn.
Re: ggs theary by gorlov ? + aoa for darius rotors (3.00 / 0) (#8)
by hvirtane (hannu_markus_virtanen(at)yahoo(dot)com) on Tue Jul 5th, 2005 at 10:29:54 AM MST
I think that you could start with
a similar solidity as used with
Darrieus machines. There is available
one really good web page:
http://windturbine-analysis.com/index.htm
In his prototype the guy is using a rather
high solidity Nc/D = 0,42
This is where the real science
is required, to produce
the optimum ratio between
vain thickness and vain width.
You are considering using cloth
Yes, if you'll use a tube on
the leading edge, I think
that cloth could be a good choice.
I think that the airfoil
would form itself quite well.
One of my friends In Finland
has made HAWT rotor blades
using a tube in the thickest
part of the airfoil, polyurethane
on the leading edge, a steel wire
on the trailing edge and covered the
blades with cloth. They are working
really well.
you have drawn.
I think that would
be a good idea.
Do you think to use a tube
on the leading edge?
One more drawing with also some
new suggestions. You might try
using polyurethane on the leading
edge and cloth to cover the vanes?
Which kind of tube have you tried to use?
Metal or plastic?
How thick are the walls of your bucket?
Is the bucket made of metal?
Have you got any pictures of your
prototype?
Re: ggs theary by gorlov ? + aoa for darius rotors (3.00 / 0) (#9)
by electrondady1 on Tue Jul 5th, 2005 at 07:16:31 PM MST
hannu thanks once more for all these links. the paint bucket is probably high density polyetheline. the wall thickness is  2.5mm. they appear to be injection molded , with built in stiffening rings. i have built some drag type mills from this same material, it is very strong. the second airfoil design is the one i will attempt. if i get it to function i will post a photo.
Re: ggs theary by gorlov ? + aoa for darius rotors (3.00 / 0) (#10)
by hvirtane (hannu_markus_virtanen(at)yahoo(dot)com) on Thu Jul 7th, 2005 at 09:40:18 AM MST
your material sounds very nice.
I think that also metal buckets
might work.
I'm looking for similar
buckets to make some
experiments, too.
I made yesterday still more
drawings.
This draft above is quite similar
as I made earlier, suggesting developments
of 'WindstuffEd's 'Lenz' turbine. But if
you will make your machine with skewed
vanes like in 'Gorlov' turbine, you can
using waste materials from the bucket,
make 'the crossflow turbine' inside
skewed, too.
Then still another possibility would be to use
waste material from the bucket to fill
the vanes outside with strips. I'm not
sure, if it is necessary to fill the
leading edge rough shapes
with some kind plastic.
The vanes might work well without
filling, too.
Re: ggs theary by gorlov ? + aoa for darius rotors (3.00 / 0) (#11)
by electrondady1 on Thu Jul 7th, 2005 at 05:44:03 PM MST
hannu , my degree is industrial design but i now make my living painting the country homes of wealthy people. finding paint buckets is not a problem for me! you could contact a painting contractor. also, the buckets used in restaurants for  cooking oil. i just purchased (used) 4 large plastic barrels 56cmx92cm . these objects will eventually live exciting lives as windmills! if you wish to see my first windmill look in the wind section under"need a vawt design" . tom w was able to form a link to my video. these gorlov style windmills look very nice when they are spining,if i can make one work, it would be acceptable in an urban setting.
Re: ggs theary by gorlov ? + aoa for darius rotors (3.00 / 0) (#12)
by hvirtane (hannu_markus_virtanen(at)yahoo(dot)com) on Fri Jul 8th, 2005 at 10:31:22 AM MST
you could contact
That sounds good.
I've been myself as well
looking for such a design,
which could be built
in a factory besides
being a good design
for handicrafts people.
One of my good friends
here, Erkki Nousiainen
has built maybe
the biggest Savonius of
the world using old
paint buckets.
But he opened them and used
the metal plates by bending
them into new shapes.
Please see an old picture
of his Savonius below.
It is about 15 m tall...
I'm becoming quite exited
with this project. I started
to think about 'a gorlov design'
already more than half year ago,
but I've been now outside
my country for a while
and did not have time
and possibilities
for that project.
I think that some kind of Gorlov
turbine might be the best design
for urban areas.
I will start making a prototype
myself also soon.
I made still a couple of
more design drawings.
I think that using the waste
material from the bucket as
the last picture even
without 'the savonius
vanes' inside will
probably work.
We just need right dimensions
and airfoil shapes.
I tried to see your video,
but unfortunately that
video format doesn't work in
my machine (I'm using
debian gnu/linux). Maybe
you could convert it into
another format?
Re: ggs theary by gorlov ? + aoa for darius rotors (3.00 / 0) (#13)
by electrondady1 on Fri Jul 8th, 2005 at 07:38:31 PM MST
very good work hannu , here's a thought, if at the proto type stage the internal savonas was built in a sub section that could be placed in multiple positions (rotatable and locked) allowing experimentation as to the optimun relationship between it and the out side wings . i think the air coming off the convex side of the savonas could be put to use to trigger or enhanse lift in the gorlov or darius rotors.. perhaps, this relationship has alreadey been documented.
Re: ggs theary by gorlov ? + aoa for darius rotors (3.00 / 0) (#14)
by electrondady1 on Fri Jul 8th, 2005 at 08:15:09 PM MST
i like you friends big windmill. does it make electricity?  it might not be good for urban use !!!! ha!
Re: ggs theary by gorlov ? + aoa for darius rotors (3.00 / 0) (#15)
by electrondady1 on Mon Jul 11th, 2005 at 10:10:34 PM MST
hannu i have no knowlege on how to convert the video to an other format.
you have drawn the gorlov/darious wings to be 1/6 of the surface do you consider this to be optimum.
· Also by electrondady1
