found perf hub for pvc blades
By georgeodjungle, Section Mechanical
Posted on Sun Jul 03, 2005 at 06:20:21 PM MST
71 corn bineder hub
sorry don't have digital camera
SO, any ways:
this hub is off a 71 HI 1210 with a 392 ci. van, suv same thing!
grind the rivets, all 30 of-em, 5 on each blade.
seperate the 2 hubs from the blades.yep 2 hubs.
drill the 4" pvc blades with 1/4 inch. bit,in the right places.oblong-em to adjust pitch and fine tune.
assemble.
just a lil gap, smuches just fine. i think 6" pvc would be in exact fit.
it's nice to recycle.
any body know if other fan blades work as well?
found perf hub for pvc blades | 9 comments (9 topical)
Re: found perf hub for pvc blades (3.00 / 0) (#1)
by drdongle on Sun Jul 03, 2005 at 01:09:25 PM MST
Your going to have to clarify... what the heck is a 71 HI 1210?? and please speak  s l o w e r and in plain english, I can follow any of what you said, sorry not trying to be difficult.
Carpe Vigor, Dr.D
A blow to the brain bucket with a BFH on the PDQ (3.00 / 0) (#8)
by TomW on Mon Jul 04, 2005 at 10:21:02 AM MST
I tend to agree, Dr. D, abbreviation and "cool" lingo just do not get the point across to the majority of the users. Note this is constructive criticism george so don't take it personally.
I had to read the replies to figure out what george was talking about here. Poor spelling and improper capitalization I can read around but too much slang combined with  incomplete sentences make it gibberish especially when you consider that a good portion of our user base have English as a second or third language.
Just the view from here.
Oh, and it has been pointed out before that automotive cooling fans and hubs can be put to good use in this area. I suspect you want the solid type rather than the clutch fan type, also. Grab the pulley along with it and you could fool with some belt drive gearing too.
Re: A blow to the brain bucket with a BFH (3.00 / 0) (#9)
by georgeodjungle on Tue Jul 05, 2005 at 12:04:12 AM MST
i'll try to cut the lingo and
hammers don't work good.
it gets tried  once in a while, i usally take them a way from them first.
the'll usaly grab any thing close.just the ones that realy realy don't whant to go back to jail.
any way:
i searched! could be my poor spelling.
the pully is still on the water pump.
i went to an electric fan.better mpg.
it has magnets in it. didn't get alot of power out of.
8 volts at 3600 rpm
yes it is solid and curved just right.
two in one ready to make a blade sandwich.
does the cheepy cameras post good?
Re: found perf hub for pvc blades (3.00 / 0) (#2)
by nanotech on Sun Jul 03, 2005 at 01:17:36 PM MST
I think he meant to type IH..
Which is International Harvester.  The people that brought us the venerable Scout and Scout II SUV in the late 60's to 70's.
The 1210 to me sounds like the International Travelall....
but after a quick search, maybe not.  Possibly a tractor of some sort.....
__________________________________________
My ship finally came in, but it was the Kobayashi Maru!
Re: found perf hub for pvc blades (3.00 / 0) (#3)
by georgeodjungle on Sun Jul 03, 2005 at 01:43:03 PM MST
nice rides!!! put lockers-in -em and go any where.
not the red street pounder.
yep! just like the blue one.the 3/4 ton travelall but white.
and bigger mirrors.
and part time 4x4.
ops i put hi not ih sorry.
lets see the fan blades.
i realy should get a camera.
Re: found perf hub for pvc blades (3.00 / 0) (#4)
by georgeodjungle on Sun Jul 03, 2005 at 01:53:34 PM MST
allso sorry putting down the lil red one.
lock the diffs.
ditch the side pipes.
turn the scoop around.
rotate the leaf spring mounts.
move the shocks.
ditch the swaybar.
shim head gaskits.
ops this isn't a 4x4 site.
nice scout any ways.
Re: found perf hub for pvc blades (3.00 / 0) (#5)
by georgeodjungle on Sun Jul 03, 2005 at 02:00:10 PM MST
check out pirate4x4.com
r
this site rocks.
Re: found perf hub for pvc blades (3.00 / 0) (#6)
by electrondady1 on Sun Jul 03, 2005 at 10:49:54 PM MST
here's mine
Re: found perf hub for pvc blades (3.00 / 0) (#7)
by georgeodjungle on Sun Jul 03, 2005 at 11:13:08 PM MST
where's the fan blade?
· Also by georgeodjungle
