Has anyone tried to use something like this to make a wind power genny.Could this be mounted with a prop and if so what size prop would it take 8ft 0r 10ft.Maybe driven with a chain sprocket.If I could get just one tenth of its rated output,in my low wind situation it might surfice.Go ahead and break the bad news to me,I was going to break down and cry later today anyhow....Thank you for your help. MelTx
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?function=Search
10,000 WATTS PEAK/7200 WATTS RATED BELT-DRIVEN GENERATOR HEAD
Build your own belt driven brushless generator
3600 RPM
Uses a 20 HP gas or diesel engine for maximum performance
Comes with two 20 amp 120 volt receptacles and one 30 amp 120/240 volt twistlock receptacle
Circuit breaker protected
92 lb. shipping weight
Keyway: 1/4''; Shaft: 1'' diameter x 2-1/4'' long; Belt driven
ITEM 45416-1VGA
Editors Note:
Gee, Mel, I can't make that link work. please provide a working link so folks can actually maybe help.
Editor.
80 Scoop users have viewed this posting.
