I noticed that an avi was posted, a vawt with
6 blades one had a small red patch, but it was
still spinning too fast to count by eye...
This would be especially nice for youngsters
making the Pico Turbine, it calls for a wooden
dowel for the axle, about 8 inches.......
now if it were about 2 ft higher you could paint
a highly visible spiral stripe on the top exposed
extended axle a lead or 'thread' of 1 per inch,
the eye can easily follow the spiral from bottom
to top quickly jumping back down to the bottom
when you reach the top....24 turns per cycle,
setting a timer for 10 seconds it, the rpm could
be easily determined, or so I would imagine.
Similar to using good ol' nut and threaded rod
method.
( :>) Norm.
