Magnetek Aurora Grid Tie Inverter Good/Bad?
By tcrenshaw, Section Controls
Posted on Thu Aug 25, 2005 at 01:49:42 AM MST
Looking at a Magnetek Aurora Grid Tie Inverter
I have 20 36 cell solar panels and am ready to look at purchasing a grid tie inverter to continue my experimentation with solar. Each panel puts out about 19 volts and 2 amps in direct sunlight. Measurement is taken with a standard DVOM capable of 10 amp measurements. No load on the panel when measured. I was looking at the Trace Xantrex and Sunny Boy grid tie inverters and someone pointed me to Magnetck and the Aurora line of inverters. I've looked at them and they compare very well against the Xantrex and Sunny Boy equipment. Has anyone heard of or had experience good and bad with the Magnetek brand? Thanks for your input.
Magnetek Aurora Grid Tie Inverter Good/Bad? | 11 comments (11 topical)
Re: Magnetek Aurora Grid Tie Inverter Good/Bad? (3.00 / 0) (#1)
by old55olds on Thu Aug 25, 2005 at 08:18:36 AM MST
Just for argument sake
20 panels with 2 Amp @ short circuit. So we will get probably 1.5 amps at 12 volts.
So 18 Watt panels times 20 is 360 Watts
5 hour days of ideal sunlight is 360 X 5 equals 1.8 KWH per day
Power produced in 365 days (if you are very lucky and have no clouds) 657 KWH
So the power company pays say .06 cents per KWH would produce $39.42 per year.
I can buy power at .06 cents per KWH now so it will depend on what your power company sells it for but generally 1/2 of that.
Forget the grid tie invertor and pick up one from Wally mart and a couple of batteries.
I have 18 123 watt panels, A Bergy XL 1.2, and a listeroid  12 hp running on free fuel and can't justify trying to sell it back to the grid.  At least check very carefully with your utility before running out to spend money.
Just my opinion for what it is worth. My wife says nothing.
Ken
Re: Magnetek Aurora Grid Tie Inverter Good/Bad? (3.00 / 0) (#5)
by tcrenshaw on Thu Aug 25, 2005 at 05:02:46 PM MST
Thanks for your opinion on the feasibility of this but let me re-state this - This is an experiment. If I was looking at making a quick return I surely wouldn't use this method. The power here in Dallas is .098 to .13 per KWH, but again, I'm not looking at this for anything other than to see what real world results are. I have the money to buy the equipment; it's a hobby I enjoy. I'm looking for opinion of how well the Magnetek inverters run against the Xantrex and Sunny Boy equipment.
Thanks, Todd Crenshaw
Re: Magnetek Aurora Grid Tie Inverter Good/Bad? (3.00 / 0) (#7)
by finnsawyer on Fri Aug 26, 2005 at 07:49:33 AM MST
But even so, as old55olds points out you need to know what you are dealing with, and you don't.  You need to determine the maximum power output for a panel.  You do that by hanging different loads (resistors) across a panel for constant illumination {noon day sun).  You then measure the voltage and calculate the power into the load.  You plot that power versus voltage to find its maximum.  That then determines you (best) working voltage.  You can then figure how to combine the panels to drive the inverter and what kind of payback you can expect.  This information might also help you in determining which inverter to buy.
GeoM
Re: Magnetek Aurora Grid Tie Inverter Good/Bad? (3.00 / 0) (#2)
by Nando on Thu Aug 25, 2005 at 09:09:41 AM MST
I think that the idea of grid tied would be very expensive to you without any return for many, many years -- it does not have a good value for you --
KEN is right, one needs to do some simple mathematics to determine the practicability of a project and the benefits of it that in this case are negative or in the red for you.
Nando
Re: Magnetek Aurora Grid Tie Inverter Good/Bad? (3.00 / 0) (#3)
by Shadow on Thu Aug 25, 2005 at 09:30:13 AM MST
Ken, (old55olds) I'm interested in your Listeroid setup. what kind of generator configuration is hooked to it? Where can one be found? I think youre in Alta if I remember, I'm in Sask. Thanks..
Re: Magnetek Aurora Grid Tie Inverter Good/Bad? (3.00 / 0) (#6)
by old55olds on Fri Aug 26, 2005 at 06:51:41 AM MST
You can email me
recore-at-sprint-dot-ca
I have a Vidhata 12/2 hooked to a 10 KW generator. So far no problems. Located at Onoway. 50 miles out of Edmonton. It is running on used refrigeration oil. And yes there is a learning curve. Hey my 55 olds came origionally from Sask.
Ken
Re: Magnetek Aurora Grid Tie Inverter Good/Bad? (3.00 / 0) (#4)
by bob g on Thu Aug 25, 2005 at 04:45:10 PM MST
for the listeroid/generators
see george at  utterpower(dot)com
he has alot of info, and is located in kent washington
bob g
Re: Magnetek Aurora Grid Tie Inverter Good/Bad? (3.00 / 0) (#8)
by old55olds on Fri Aug 26, 2005 at 08:45:45 AM MST
I have no experience with the magnetek and no one that I know has either. I do know that the trace invertors have been reliable. I looked at their website and it is interesting to be sure. Personally I would go for the 4000 which gives you the option of using two seperate strings of solar panels. One thing to remember is that if the power goes down they will not work. That is to protect the line workers. However I imagine that that is not a problem as your standby generator would kick in. But you must still isolate it from the line in case of a power outage. Your electrical company would have to authorize hookup also.
Hope that helps.
For my money(but then I don't have much) I would go the trace or sunnyboy. They have the track record.
Ken
Re: Magnetek Aurora Grid Tie Inverter Good/Bad? (3.00 / 0) (#9)
by tcrenshaw on Fri Aug 26, 2005 at 08:48:57 PM MST
Thanks Ken. I think I'm leaning towards what your saying here about track records. Since this is just playing around more than anything, I would like to be able to eBay the inverter I use once I play with it for a half year or year. Having a "brand" name may be the way to go with this.
Thanks again.
Re: Magnetek Aurora Grid Tie Inverter Good/Bad? (3.00 / 0) (#10)
by nickelbender on Wed Oct 05, 2005 at 10:58:31 AM MST
Magnetek has a history of purchasing electronics made by other people and rebranding it...
In they have sold drives manufactured by KB Penta electronics and Yaskawa
This isn't a bad thing, in fact if this IS a Yaskawa it's probably bullet proof.
Also Yasakawa now has a sales office in the southern US some where you will probably see in there product line if they are the manufacturer
Re: Magnetek Aurora Grid Tie Inverter Good/Bad? (3.00 / 0) (#11)
by nickelbender on Wed Oct 05, 2005 at 11:00:40 AM MST
Nice typing eh? I should read this before hit send lest you all think me drunk lol!
  133 Scoop users have viewed this posting.
· Also by tcrenshaw
