What would happen in regards to useful coil EMF if a ring mangent
were mounted to disc rotor via a bolt in its center?
Would make stacking em up easier I assume if needed or desired.
I assume ring shaped neo's come with N/S poles on flat faces, yes/no?
I also assume one could water jet a hole in solid neo's but don't know
what effect on the flux this may have or if it even matters.
I assume that steel bolts or ferric supports at edges of magnets would
divert flux from projecting toward coils, but alas, duh I don't know.
hobot
Arkanaas |
75 Scoop users have viewed this posting.
