I read the post on the box fan conversion. Thank you for all the ideas Ghurd. I had one here and tore into it. The old wire came off and re-wired using 20-gauge wire I pulled off a couple of blenders I had. 100 winds per coil. Alternating cw-ccw all the way around the stator. 6 coils.
The rotor I cut to 8 sides using dimensions off the turbo-cad calculating for ½ x ½ x ¼ neos I had here.
Now for my problem. I wired it 3-phase star and got only .05 volts. Wired it series and got the same thing, parallel even got the same thing.
I even tore the mags off and put only 4 of them on (N-S-N-S of course.) and got the same result.
Could the mags be not big enough? Not enough windings? Not getting it to spin fast enough?
Any thoughts would be very helpful.
124 Scoop users have viewed this posting.
