| got back yesterday with the crates,
got them opened today, and was very happy with the contents
engine #1, a changfa 12 hp diesel electric start, 350 lbs of very well constructed engine
engine #2, a chanfa 6 hp diesel crank start, 135 lbs of same.
both engine's are water cooled,
i cant tell you how impressed i am with these units so far, it is amazing to me how much you get for the money with these engines.
the 12hp will be mated to a 7.5 kwatt ST head, another heavy unit, 1800rpm 120/240 60hz alterntor head.
the 6 hp will be mated with a prestolite/leece neville load handler alternator, 140 amp at 12 volt for battery charging contolled by a 4 stage marine controller, and a refrigeration compressor. i will incorporate a relay system to switch between these two loads as demand dictates.
we did some testing of fuels today, or rather started a long list of alternative fuels.
we started with waste hydraulic oil as a diesel replacement, and found it to start and run without odor, or smoke. Was surprised at the ourcome of that expercise,
stepped up to running 20 weight motor oil and found it also to run flawlessly in a the 12 hp at operating temperature. although it does smoke a bit when at room temp 75 degrees F.
we didnt go any heavier with the oils today, and don't plan to. The vicosity seems to be as heavy as i would ever want to use anyway.
i think i will wait until the engines are mounted to do testing in dual fuel modes, ie. wood gas, alcohol and propane.
if all goes as expected these engines should run well on just about anything i can get my hands on that is properly filtered, and of suitable viscosity to inject, and of course veggy oils, both new and reclaimed.
our engine oil supplier has agreed to supply us with a 375 gallon tote full of the tail drainings of 55 gallon drums they have as returns. this oil will be a mix of everything from motor oil to hydraulic and transmission fluids. we may need to correct or lower the viscosity with kerosene or diesel to use it though. If that can be made to work, the possibility of a useable no cost/low cast fuel is pretty exciting.
boy this is just like christmas :)
bob g |
102 Scoop users have viewed this posting.
