Thinking about my future gen I thought a good start to look for magnets.
Before making a choice I think it would be good to review all the parameters:
1. Volume.
The more volume,the better(more flux).More flux means less windings for
the same voltage and power what means more place for thicker wire = less
losses in the gen = higher maximum power.
For smaller gennies (<7') rpm is higher,power output lower =smaller magnets.
Is this right?
What should be the minimum volume of NdFeB for a 7' genny.(9coils-12 pole)
I found out 6 - 10 cm cube is still reasonable priced ,4-10 Euro (about 4.8 - 12 $)
2 Surface.
Some say bigger surface is better.
But shouldn't the surface be smal enough to fit in the hole of the coils
so all the flux pass inside the windings? Or can it be a bit bigger?
3 Shape.
Rectangular or circular.
My intuition says circular is better because it fits better in the hole of
a coil.Is the wedge-shape really the best?Isn't there some of the flux in the corners of the magnets that doesn't pass through (all) the windings of the coils
(that are allways more or less round).
The coils are mostly oval so shouldn't be the ideal shape of the magnet
kind of oval(=elips?).
The closest to oval shape in commerce is circular.
Is a choice of circular magnets of about 7cm cube for exemple 1.5"diam 1/4"thick
big enough? Bigger? rectangular? Thicker and smaller?Thinner and larger?
What is the volume of the wedges I saw on windstuff?
And Thanks for all the great information I find on this site.
Stonebrain
142 Scoop users have viewed this posting.
