| although a bit crude we had to know if the thing would run in dual fuel mode.
first i might add my friend ran the engine on straight 50 weight last night, this morning we had a little problem getting it to fire on this heavy of oil. i don't know why he did it but none the less it did start and smoke a bit, not horrible but smoke none the less. after about 2 minutes the thing came up to temp and cleared the exhaust considerably. i think if the fuel/oil was preheated it would have no starting problems or smoke.
he says 90 weight is next, i told him, "u mark this engine as yours" mine is going to stay in the crate :)
i don't think he is serious, but you never can tell.
now dual fuel:
a diesel engine has no butterfly in the intake and as such no manifold vacuum, the way the rpm is regulated is by means of fuel delivery, more fuel more rpm, more load/less rpm and the govenor opens the fuel rack and delivers more fuel. so air fuel ratio's are not a factor, low ratio equals lower rpm or lower power. higher fuel air ration, more rpm and more power.
so i considered that if the engine was brought up to maximum governed rpm the fuel rack is advanced to deliver the amount of fuel needed to maintain the 2000 rpm max rating. any addition of fuel to the engine thru the intake, ie. propane which richens the air fuel mix, in this case would do one of two things.
- the engine would gain rpm in proportion to the additional fuel delivered (propane) if the govenor did not taper back the diesel fuel, or
- the engine rpm would remain stable, indicating that the fuel rack had been backed off thus delivering less diesel to maintain the load and rpm set point.
what we found was indeed the fuel rack must be tapering back the amount of diesel injected as the rpm remained stable, no change.
the only change we noted was a slight softening of the normal diesel knock.
now i havent set up the necessary graduated pippets (sp) to determine the offset of diesel in dual fuel mode, but
we have determined that the engine will run in dual fuel mode, without any secondary detonation or secondary knock, which reportedly happens at low loading of larger engines.
this looks very promising at this point,
i will need to get the graduated cylinders to montitor and calculate the fuel offset, and do more testing, likely after we have everything bolted down and a load attached.
i may try alcohol as a dual fuel suppliment in a crude experiment this weekend and get back with the results
the next stage is the design and implimentation of these engines into a cogeneration package, that i am very excited about. :)
bob g |
111 Scoop users have viewed this posting.
