Vawt Darrieus questions
By thefinis, Section Wind Posted on Wed Jan 18, 2006 at 06:28:56 PM MST
Effect of wind shadow of starter Savonius on Darrieus machine and other questions
| I know that on the downwind Hawts that the tower shadow caused many problems with torque pluse and stress on the blades. Does anyone know if a Savonius rotor used in the middle of a straight bladed Darrieus would do the same? For a two bladed (even numbered)turbine the shadow on the downwind blade would happen at what I think is the top of the power curve for the upwind blade and it just seems to me that it would cause a lot of stress and torque pluse. A two bladed machine will have torque pluse anyway going from parrallel to crosswind so I don't want to make it worse. I know that a three bladed turbine would dampen the pluses out but I want to build it h--l for stout so I am trying to make it with straight through support arms.
My design is for the S rotor to run at .75 TSR and the Darrieus to run at 5 TSR when up to speed. It would have sailwing airfoils set at an attack angle of 8 and a solidity of 5% with two blades. At TSR=5 it should see an apparent wind at all times but with a changing angle of attack. Here is a good website for showing apparent wind on a Darrieus http://purrfectcatshelter.org:8080/james/darrius/ (wind blowing up means up the page). Now for a fixed angle of attack shouldn't I set it at what would be best if it was a Hawt? Sandia did a lot of testing on different attack angles but I have been unable to find if they decided on a best angle for their Darrieus. Does anyone have a web address for the DOE document if Sandia came out with guide lines for angle of attack at various TSR? While I'm asking does anyone have windturbine-analysis.com pages cached as the address now takes you to a search engine.
Should a Vawt turn counterclockwise in the northern hemisphere? Does it make any measureable difference?
Sorry for all the questions but I have been lurking for sometime. Started out researching long ago during the last energy crunch. I got sidetracked when oil got cheap and plentiful with the electric companies not wanting to talk about interconnection. I am guessing that I have a year or two at best to be able to get my electric company to play ball before they suck back up into their shell. I am building the middle section of my turbine now but would love to hear your thoughts on any of my questions especially the wind shadow effect of the Savonius.
Finis |
148 Scoop users have viewed this posting.
