Hi,this is my 3rd post and I,m no pro at this. I have built 2 hugh,s 8 ft and a Hugh,s 4 ft for my camp. They all are performing.
I was admiring Dans 14 foot machine and was going that way with a larger disc as Dan said he would have used a slightly larger disc next time. I checked wondermagnet and they only had 4 big mags on hand at the time.
I then run across a couple post on 18 in. disc with 1*2*.5 mags with 18 coils, 3 phase @ 12 volts and decided I would go with this since I had the smaller mags. I placed my mags at 15 degrees and put paper (trial) coils around my 22 in stator to make sure there was enough room.
I wound 3 coils, #1 85 turns of #15 (I had this one from hugh,s 4 ft. machine) and got 3.2 volts ac @ 60 r.p.m, 0.7 ohms #2 34 turns of #14.5 (2 in hand) and got 1.1 volts ac @ 60 r.p.m 0.8 ohms #3 Someone suggested 12 turns of # 14 (4 in hand) and I got 0.2 volts ac @60 rpm 0.7 ohms These test were done with one coil and both disc on the axle.
How do I go about calculating (lets take #2 coil for instance) the total voltage, for when the 18 coils are on the stator. What voltage must I get from this one coil, in order to get a cut in of 80-120 r.p.m and what can I expect for power from this machine.
Dan, if your reading this post, I will be on the phone sometime next week for information on the availability of them mags you used on the 14 ft machine with 14 in. disc/ 9 coils ,3 phase. I already have that stator cast (24 wraps of #14 4 in hand wired for 12 volts) and hanging on the wall, just waiting for magnets. Thanks to anyone out there that can help me. email me if you like: mitchelllake@yahoo.com
Mitcamp |
153 Scoop users have viewed this posting.
