| The topic of increasing the magnet plate diameter and moving the magnets farther from the axis of rotation has been discussed before and is mentioned often in various posts. As everyone knows this will increase the velocity of the magnets moving past the coil. There have been various opinions expressed as to the effect this has on the voltage one gets from a coil. I have had my opinion but since it gets mentioned so often I decided to run an experiment to see what really happens.
First setup:
4 magnets placed equal distance from each other on the plate at a radius of 20 MM
Second setup:
Same 4 magnets placed equal distance from each other on the plate at a radius of 40 MM. (double the radius of the first setup and double the velocity of the magnets past the coil)
In each case the RPM was the same and the spacing from the magnets to the coil was the same. The RMS ac voltage from the coil was measured for each setup.
What was the result of setup number 2 compared to setup number 1 ?
- The output voltage decreased by 2X
- The output voltage decreased by 1.41X
- The output voltage was the same in both setups
- The output voltage increased by 1.41X
- The output voltage increased by 2X
Feel free to answer with your best educated guess.
I will provide the answer tomorrow.
John |
244 Scoop users have viewed this posting.
