| i'm building an outside woodstove/casting furnace from and old water tank.
i want to the capture the heat for my house by wraping the stove with airduct and pulling the hot air into the house with a fan.that should be simple and safe. i plan on placeing the firebox and air duct in a large pile of sand .
the air supply for the stove is a little different . it's starts near the front next to the door and runs through a steel pipe and ends at the back of the stove.
i did it like this be cause i would sometimes like to do some lost wax metal casting and blowing air under the fire can make it hot enough to melt copper and aluminum.
i intended the entire stove to be at a slight angle so the fuel would have a tendancy to fall down to the back and burn up completly.
i was thinking the combustion would take place towards the back of the stove and the hot gases would follow the top and exit through a vertical chimmney near the front
but this is kind of the opposite of how a normal stove works.
maybe the door would get too hot and the glass would break. |
165 Scoop users have viewed this posting.
