I have read lots of different post here on the board about diodes. I am not very good when it comes to electronics as you can see from my previous post here, I'm always asking questions. Could somone tell me about the size of a diode needed for a DC motor thats being used for a wind genny that at its peak produces about 20 amps at 40 volts. I have some schottky diodes, there rating is 80 amp 45 volts. From what I have read these are not big enough. I have a 12 volt battery bank. Should the blocking diode being used be twice the open voltage? twice the current?
I have seen some for sale rated at 1000 volt 35 amp. Why would you need 1000 volt? I just don't understand this very well. If my genny is putting out 800 watts can I just use a diode that is capable of 1600 watts? [ 40 amps x 40 volts ] Or tell me diodes don't work like that. Can I put more diodes together to get a higher rating, or should I just buy a bigger one? I now its hard to explain something like this to an idiot like me, but your help is really appreciated. |
134 Scoop users have viewed this posting.
