| Another fun project to see if its possible to get some decient power from a radial air core alternator.
Started with some plastic and a section of 6 inch sch40 pipe for the drum. Mounted the magnets and drilled the end plates. It uses 18 magnets and 54 coils. Each coil is 11 turns. I wanted to keep the magnets and wire as close to each other as possible. Below is a photo of the magnet rotor and drum completed...
Another shot of the bearing assembly attatched to the drum and rotor installed... The drum spacer is an .050" thick sheet of PVC...
And finally all wired up...
Since this was a test machine I really didn't want to waste any good wire on it and wound it with some used stuff I had. ( Hence the really sloppy coils )
So with a quick turn, and wired in star, it jumped to 15 volts right off. Turning it slowly with the tach it makes 12 volts at 106 rpm. I haven't had it on the lathe for any tests yet so thats all I have right now.
This was a fairly quick simple project overall. I'm not sure what type of plastic the black drum is but I'll never use it again... It is a nightmare... I spent more time cleaning it up than drilling the 108 holes in it.
If I made some molds for the plastic parts I'd bet this thing could be built in a few hours...
This design definately needs a considerable amount of refining but has quite a bit of potential overall.
Lots of fun in anycase... kind of disappointed when it was finished, guess I'll have to build another one...
253 Scoop users have viewed this posting.
