I have an idea I would like to try but I'll post it first and see if anyone thinks it might work.
I have a 7.5hp motor that is burnd't out that I will use as a motor conversion. It has a 36 slot stator and I was thinking of winding 18 coils,using slots 1 and 2 for the first coil,slots 3 and 4 for the second coil and so on for a total of 18 coils. Each coil would be rectified independantly and the DC voltage from each diode would be tied to a common terminal. A 1/2" wide x 4" long magnet would span a single stator bar. My next question is, being that I'm not concerned about anything being in phase,would it work to use 24 magnets on the rotor without the magnets being skewed. I would not skew the stator laminations either.I'm thinking an odd number of magnets would keep cogging to a minimum. I got this idea from the axial flux alternator(9 coils-12 magnets). Would the losses from 18 recifiers make this idea not possible? Would it make so much noise and vibration that it would drive the neighbors nuts? I'm I nuts?
Any comments or suggestions!!!
windy
103 Scoop users have viewed this posting.
