.......The chest itself is large enough to put in 4 six packs of beer. It's missing its lid. The cover to the electrics of it say "input: 12 volts @ 5 amps" The fins outside get warm and the fins inside get cool. Each set of fins is approx. 3"x5" There is one small motor with a long armature that has a small squirecage type fan on each end, blowing on each set of fins. It wouldn't stay spinning when I first connectecd it to my car battery, engine off, but after some spray WD-40 is does. Maybe a bit slow, but if it was spinning twice as fast I can't imagine any heat or cold being moved off the fins. I'll give this cooler a full checkout before I spend any money: wired to the battery with the car running and checking temps after 30 minutes.
Finally my question,(if this thing checks out):
Can you tell me what size solar panel I'd need to run this. The cooler would be wired with what ever size wire is needed to make it effectient and maybe 30 feet from the panel. I'm thinking I'd like a panel that puts out 17 volts, that seems to be a common amount and I'd also like to be able to run a portable radio (uses 8 size D batteries) The radio plays well from a 5 watt panel, but needs a 10 watt-er to be able to play CD's. This will be a little hobby project and I'm thinking if I put all the mechanics in a smaller cooler, with 6" of rigid foam insulation I could keep a 6 pack real cool in the shade, on the patio. I'm thinking the more 'fan' blowing on these fins the better. I could find a couple of 3 or 4" fans like computers use and run them off the panel also. So again, what size panel would make this all happen for me. And figure in some 'lee-way' cause I don't want cool beer, I want Cold beer. I'm not interested in any battery backup. Could all this happen for $100? Thanks for your time and knowledge. |
