Hello
I working on floor heat for shop/shed and
was wondering if anybody out there knows of something non-freezing hopefully non-toxic and
not going to cost so much it wouldn't be worth
the attempt to do this.
I'll be using plastic floor hoses for now,
(about the only thing rated for hot water besides
copper and SS tubing), lawn hoses all stated "Not for Hot Water use".
Metal bottom to shed, 3"X3" hard wood supports @ 16" centers, insulation, 1/2" old floor ply, hoses and 1" upper floor support strips, 3/4" new ply floor.
Will be using a few different ways to add heat to the liquid, solar collector's,(copper tubes in glass covered box with copper sheet wrapping and a old dish with mirrors also a lawn edge trim black plastic 4" flap type, ect,..ect.), copper tubes in heat box I run a little propain heater inside of this metal box to try to save a bit of heat in something that retains heat better than air, works well!
I'll be messing around with a "Eddy Currant" type system soon also, question about this on flux flow.
single rotor would need a metal plate behind copper tubes for propper flux return wouldn't it?
Anyway
Thanks for being "The Site", for hooking people on
R.E. and better lifestyles!
189 Scoop users have viewed this posting.
