| Hello,
I want to power my laptop computer off my 24V battery bank without going from 24Vdc to 110Vac to 15Vdc. Instead I want to go directly from 24Vdc to 15Vdc. If my understanding is correct I only need to add a resister to the line to give me a voltage drop to 15V, is the correct?
My laptop draws 75 watts. If my understanding is correct I need a 1.8 ohm resister rated for 75 watts. Is that correct?
V = iR
9V drop = 5A * 1.8ohm
Does this yield 5A at 15V? 5V at 15V is what the laptop AC adaptor output is rated.
I ask this question because I keep getting confused about the current value 3A at 25V = 5A at 15V so which current value do you use in the V=iR equation to determine the desired R value.
Also, in the resister causing the voltage drop where does the lost energy go? If 5A at 24V becomes 5A at 15V there appears to be a loss of 45 watts. I presume my understanding is wrong or the resister would melt.
What is an example of a resister rated for 75 watts (or more)?
I see the OtherPower.com web site says Radio Shack has a product to do this but I'd like to understand the process better.
Thank you,
Rob
103 Scoop users have viewed this posting.
