I now have a pair of lakewood fans donated, as well as an edison fan with a similar motor. All 3 have been stripped down. 1-2 amps each, for two of them beats what my solar is doing on these dismal winter days. I'm seeing the first charging amps in 3 days this morning.
I think I will take a break from the axial to try tinkering with these. My thought is that the worst part of them is the bushings. I will either turn the ends to fit sealed bearings, or make new end caps entirely.
It looks to me like the 4 mag arrangement seems to be the best setup due to the width of the stator segments. Would this benefit from a large number of smaller mags? My thought is the 1/8 disc X 1/16 thick 13,700 gauss neos could pack a lot of magnetic field on this motor, as well as maintain a small air gap. Is this flawed thinking? Should I shoot for larger mags on this? I will probably rewind, as they have the 3 different wire sizes in them. I would think that would be far from optimal for generating power.
I'll be cutting down the sheet metal from the "box" part of the fans to fabricate the other parts. I'm thinking 1X3 for blades, 3.5-4' high tsr rotor.
As soon as time permits, I'll draw up what I'm thinking. Merry x-mas to all. |
166 Scoop users have viewed this posting.
