Optimum Motor Conversion
By Sparky01, Section Wind
Posted on Mon Dec 04, 2006 at 08:57:09 PM MST
Looking to find the best unit to convert
I have done numerous dual rotor wind turbines and am to the point of wanting to try a motor conversion. I have access to a huge variety of motors and voltage ranges. I would like to know what would match my voltage and prop size. first, 12VDC 10' prop and Second would be a 18' prop 12VDC. Any words of wisdom would be great.
Optimum Motor Conversion | 3 comments (3 topical)
Re: Optimum Motor Conversion (3.00 / 0) (#1)
by bj on Mon Dec 04, 2006 at 03:39:04 PM MST
    Can I help?  Have a bunch as well.
    bj
bj--- Lamont, AB. Can.
Re: Optimum Motor Conversion (3.00 / 0) (#2)
by nothing to lose on Tue Dec 05, 2006 at 12:58:40 AM MST
Do searches for Zubbly, He is the king!
Jerry is good also with many, mostly 1hp or so I think. I still love the garbogens.
So many choices in motors, where to start is a hard one. I look for high voltage and high amp motors that run at low RPM. Some are fine as is some you have to rewire the coil connections inside. All I have to build a new Neo armature for to convert them to PM.
I have 12V, 24V, 48V, systems so any voltage worked for me when I built them.
Re: Optimum Motor Conversion (3.00 / 0) (#3)
by kitno455 on Tue Dec 05, 2006 at 08:43:51 AM MST
yes- seems that zubbly prefers dual voltage (230/460 or higher) 3 phase, with big bearings, and preferably rated for high efficiancy and/or inverter (VFD) duty, as this seems to give more copper and better insulation? lower rpm means higher pole count, which means more rows of smaller mags (tighter air-gap) and higher frequency at lower rpms, all of which are good. dual voltage gives you several options for wiring.
now, all that said, i have not done a three-phase conversion yet, and the above was from memory.
allan
  111 Scoop users have viewed this posting.
· Also by Sparky01
