| Hi guys, I built a very small windmill doing more than 500mA at 12v using a small stepper motor and box fan blade. Works beautifully but will wander between 3v and 15v and then above 30 mph winds, it just put itself out off the wind.
I want to charge the equivalent of 4 AA, C or D Cells with it, which seems a fine fit for emergency led lighting for the shack and the handheld CB's we have.
Now, I think trying to charge 6v battery bank at 3v is wrong... So I guess a simple zenner there would work all right. But I was thinking more of a small charger using mosfet to switch charging ON or OFF designed around a small zenner diode (6v)activating the base of the mosfet when voltage goes above the diode threshold.
Also, when the battery voltage goes above another zenner (8v), it would activate a relay (standard 6v relay)to switch from charging to load. I don't mind a mechanical relay here as it will be easyer to find, cheaper and will act as a load itself (tough quite small) but mosfets would be fine too.
It all seems pretty simple to me, but I wonder if one of you has done the same or could direct me to a simple shematic?
Thanks a lot
Parameter |
125 Scoop users have viewed this posting.
