| I have been experimenting with a 9/12 machine on and off for a few weeks, time permitting.
My delima arose when I tried a jerryrig to see what the outcome might be.The stator unit was built before jerryrig but I just wanted to learn a little via experimentation.
In a nutshell: each phase is putting out ok ac loaded or unloaded within acceptable limits for the machine.
What I do not understand is how I can have that ac to each rectifier(3) but only decimal point DC output from the rectifier(s ) individually or as a group/checked both ways... into a 2.4 ohm load (verified with a battery)-thanks for the tip, flux....and it matters not if the load is hooked to the rectifier (s) or not.
.Example...which has been doubble checked: @5volts ac in I will have perhaps .4dc out with NO amperage I can measure into the load.
I have not run the output up past 8v ac this time around because I don't know why I am having a problem.
I have not checked each rectifier on this go-round to see if one or more is bad, because they are all brand new and have been protected by fuses of a much smaller amperage than their rating ( cautious because I already lost one set ).
If it turns out that no fault lies in either the stator coils or the stator connections
I'm gonna find myself otta bullets!
I have the unit apart now..checking for any connection problems etc. so far everything seems ok.
I presume this is yet another case of me missing the obvious
which is why I'm asking questions now
thanx
spinner |
143 Scoop users have viewed this posting.
