Offset for Yaw
By coldspot, Section Mechanical Posted on Tue Mar 28, 2006 at 09:14:53 PM MST
Asking for some simple "Rules of Thumb" for amount of OFFSET from Tower center?
Hello,
Being that I have to replace my Ametek 30 VDC
Wind Mill with something else.
(See my Diary for Ametek Ceiling Fan Blade Failure)
Untill I get something different for the Ametek as
far as a hub/Blade set-up.
I'll be putting up some other mills for now for
testing mainly.(Ones I've gotten Blade/Hubs Finished for)
What I'm asking, (Post Title)
Is about how much Offset for Yaw
From Tower Center to Mill Rotor shaft center?
On my Ametek Mill, I had about 2 1/2"
But this Yaw set-up also has Three Bearings
So it would spin around easly, maybe to much.
I"ll be using the same Yaw mount for one,
It'll be the 0.07HP Induction Conversion.
So that one will have about the same Offset.
But, On my newest test tower, I'll be putting up
Maybe the CMI PM Motor, (28 Lbs).
So I'm building from scratch a yaw set-up for it
and would like it to be as good as I can do.
133 Scoop users have viewed this posting.
