This led to the simple design shown below:
All coils are wound the same way. The coils move clockwise as shown over the magnets. Coil one is over a north pole with maximum flux through it. Coil two is just about to move over a south pole. Coil three is nowhere near a magnet. As the coils move the flux through coil one will decrease causing a negative pulse. Coil two will also experience a negative pulse as it moves over the south pole. The voltages across the three coils are shown below. Note that I've ignored the ramp up and ramp down of the voltages.
The fourth curve shows the voltage waveform when the three coils are connected in series. It is a single phase series of pulses. The total resistance will be the sum of the resistances of the coils. This can then be connected to a full wave bridge rectifier. However, it is not likely anyone would build this alternator except for demonstration purposes. Let's step it up to the next level.
We now have six coils spaced every 60 degrees and four magnets spaced every 90 degrees. So, the coil to magnet ratio is always going to be 3:2 for this type of alternator. Note the peculiar geometry. The magnets are wedge shaped with an angle of MA degrees. Coil two ends at 90 - MA/2 degrees. So, coil one ends at 30 - MA/2 degrees, since it's 60 degrees behind coil two. Coil one starts at a negative angle. We define an angle WA for the angle subtended by the width of the wire. Then we can write that coil one begins at -(WA + MA/2). So, the total width of coil one is then 30 + WA. The inside dimension of the coils are then given by 30 - WA. This is the maximum size magnet that can be used given WA. In reality you would pick the size of the magnet, the width of the wire or number of turns and then size the rotor to fit the angular requirement.
As mentioned, the three phases would be connected in series to get the output. If we connect the a and b windings of each phase together first we can do some electronic alchemy. Say phase two is in the middle. We can bring out a wire from between a and b of phase two and make it common (ground or G). This is similar to a center tapped transformer winding. What does this get us? We now need only two diodes and we cut the resistance in half. We do not cut the voltage in half. The waveforms are shown below.
The peak voltage is now three quarters of what it was before. It occurs for only one third the time, however. Still this would probably not a problem, since at cut-in the power in the wind is low anyway. In fact, as the wind speed increases the peak value of the wavform will increase untill the lower pulses cause conduction. If we assume we are charging a battery with no change in voltage, the current and hence power into the battery will be limited by the alternator resistance. The plot below shows a general power curve. A hypothetical wind power curve is also shown.
Breaks in the power curve always occur near 1.5 and 3 times the battery voltage. This means that the alternator can follow the wind's power curve somewhat better than a normal alternator design. Of course, the whole thing is also dependent on the blade assembly's ability to track the wind.
One final thing. Just as you can rectify to a positive voltage, you can also rectify to a negative voltage. This means you can also connect a battery to G in a negative fashion. This allows you to get 12 volts out by using two six volt batteries or 24 volts by using two 12 volt batteries. The alternator ground floats on a battery voltage relative to system ground. |
432 Scoop users have viewed this posting.
