Has anyone tried this?
By kenl, Section Mechanical
Posted on Wed May 10, 2006 at 12:07:24 AM MST
none
 Was reading the last few new posts about different coil designs and wondered if anyone has ever overlapped their coils when building a stator?
kenny
Has anyone tried this? | 10 comments (10 topical)
Re: Has anyone tried this? (3.00 / 0) (#1)
by ghurd on Tue May 09, 2006 at 06:17:27 PM MST
http://www.windstuffnow.com/main/alt_from_scratch.htm
Ghurd.info
Re: Has anyone tried this? (3.00 / 0) (#2)
by willib on Tue May 09, 2006 at 07:51:11 PM MST
ghurd could you point me to danb's three phase wiring diagram ,i cant find it.
thanks
Carpe Ventum (seize the wind)
Re: Has anyone tried this? (3.00 / 0) (#3)
by ghurd on Wed May 10, 2006 at 05:52:33 AM MST
http://www.fieldlines.com/story/2003/9/11/84741/6758
Ghurd.info
Re: Has anyone tried this? (3.00 / 0) (#7)
by willib on Fri May 12, 2006 at 01:21:29 AM MST
Thanks !
Re: Has anyone tried this? (3.00 / 0) (#4)
by kenl on Wed May 10, 2006 at 05:18:04 PM MST
 Thanks for the link G. Guess I should have asked has anyone overlapped their coils in a typical Axial flux genny stator? Are there trade offs to using this type compared to the regular side by side coil layout? I noticed in the link that fairly thin wire was used. Is the reason for keeping the coils thin for over lapping or for achiving the desired voltage?
kenny
Re: Has anyone tried this? (3.00 / 0) (#5)
by ghurd on Thu May 11, 2006 at 06:36:21 AM MST
Hi Kenny,
"thin wire - for keeping the coils thin for over lapping or for achiving the desired voltage?"
Both. The magnets are on the small side. Big wire would be hard to fit.
The center toward the axel and the outside edge run out of space for wire. It gets thick fast.  Single rotor allows the thick parts to be bent over the laminations, out of the way, like Ed did.  I run out of space in the center.
For dual rotor, someone thought about folding the 1st and last layer kind of over the magnets on the rotor.  Wouldn't be easy to do.
magnets ]I[ magnets
Either will use more 'dead' wire in the coils, to be able to get the tops and bottoms out of the way.  Notice in the link, the 1st layer of coils are a lot longer than they need to be for a 'regular' 6/8 or 12/9 configurations.
The gain seems to be that every magnet is are always acting on 2 coils and 2 phases. And active coils are always being influenced on both legs.
Arguably, a better use of magnets and wire.  I am not qualified to get into that argument.
http://www.fieldlines.com/story/2004/6/7/21190/34164
Here is another of Ed's, same idea.
http://www.windstuffnow.com/main/microwave_wind_generator.htm
Ghurd.info
Re: Has anyone tried this? (3.00 / 0) (#6)
by kenl on Thu May 11, 2006 at 06:10:08 PM MST
 Thanks GHurd, That was one deep post. Kinda humbling reading. Anyone know if he ever built the 500w one? kenny
Re: Has anyone tried this? (3.00 / 0) (#8)
by ghurd on Fri May 12, 2006 at 06:04:47 AM MST
The kit? Yes, but I'm not sure what is still available. Look under his homepage.
Ghurd.info
Re: Has anyone tried this? (3.00 / 0) (#9)
by ghurd on Fri May 12, 2006 at 10:07:27 AM MST
Now you have that figured out, try this one...
http://www.fieldlines.com/story/2004/9/4/145716/3657
Ghurd.info
Re: Has anyone tried this? (3.00 / 0) (#10)
by kenl on Mon May 15, 2006 at 04:31:20 PM MST
 Where'my asprin? I need my asprin.
  153 Scoop users have viewed this posting.
· Also by kenl
