I have a question relating to surge and battery amp/hour ratings.
This is my experience:
I have two solar systems (actually I have more, but I'm keeping this as simple as possible).
One system has a 100 amp/hour battery (MK brand gel) and the other a 200 amp/hour battery(Universal Battery AGM). Both of these systems use the "el cheapo" Vantec brand modified square wave inverters.
The 100 amp hour battery is connected to a Vantec 750 watt inverter, and the 200 amp hour battery is connected to a 1500 watt Vantec inverter.
(I am not including info about the solar panels on these two separate systems, since for the purpose, they would be irrelevant since this situation that I describe has been done repeatedly at night. Of course, both batteries were at full charge).
I'm trying to run my television, a 27 inch Sony. Using the grid to run the TV, I have measured (at startup ,according to my kil-o-watt meter) around 600-700 watts pull for a few seconds (the surge), but then this quickly drops to a continuous 90-100 watts for the remainder of time.
Now -- here's the mystery.
When I try to run my television (the 27 inch Sony) with the 200 amp hour AGM battery/1500 watt inverter combo, it is unable to handle the surge. What happens is the TV turns on, then immediately cuts off, then "tries again" over and over again with the same result, until I disconnect the inverter. (When I use this sytem with my computer monitor, it also cuts on and off, but after about four or five tries the monitor then comes on and stays on. In fact, right now, it is running my computer monitor.) What is apparently happening is that the initial surge lowers the battery voltage so quickly and greatly that the inverter cannot run anymore and cuts off. In the case of the computer monitor, this isn't absolute, since the monitor has a smaller surge.
But when I use the smaller 100 amp hour gel battery/750 watt inverter (with the Sony TV), it handles the surge without a problem. The TV starts up without a hitch and continues until I cut it off. (From full charge, the 100 amp hour system can provide power for about an hour or two before we get into the 10% discharge level, or 12.5 volts).
In both these cases the batteries are in good shape, are both about the same age, and in both cases the batteries are fully charged when I try to use them with the TV.
My hypothesis is that -- firstly -- this has nothing to do with the inverters, which are both made by the same company, Vantec, even though they are different in capacity. It is the 750 watt Vantec that works with the TV-situation anyway, not the 1500 watt one.
My second guess is that the MK 100 amp hour gel battery is simply designed differently -- i.e. that although it is a "deep cycle" battery like the Universal 200 amp hour battery, it is designed more like a cross between a car battery and a normal deep cycle battery, and thus is better able to "shoot a lot of electrical juice out" when a strong surge is presented to it. BUT this is only a guess, however.
I should add that when the device that I run in question has a lower surge draw in the beginning, that the two systems perform as one would expect them to.
For example, when I run a 60 watt fan on my waterstove, the 200 amp hour Universal goes significantly longer than the MK 100 amp-hour battery before it drops to 12.5 volts (from full charge). In other words, there is nothing "wrong" with the bigger battery (or inverter) setup. If it was older, or simply in worse shape, I wouldn't be scratching my head.
So my question is: What is the reason for the smaller battery being able to handle the greater surge? Am I right in guessing that the MK gel battery is simply different in design? Or are gel batteries themselves known to be able to handle surge better than AGM batteries (I've never read or heard this before)?
I really am curious if anyone knows the answer, and would really appreciate any comments anyone might have.
editor says;
Try putting some whitespace in your post. One long unbroken lump really SUX to read
118 Scoop users have viewed this posting.
