| hey guys!
i completed my rotor for the 7.5hp Baldor conversion today. i drilled and threaded a total of 48 holes (8/32 SS screws). i then put locktite thread locker on all the threads and even a little under the mags. not sure if the locktite will stick to the epoxy coating on the mags, but they are very secure with just the screws.
about 6 months ago (maybe longer) i gave my ideas about magnets to a canadian supplier. i always wanted the 2x1x1/2 mags with 2 holes in them and then countersunk to accept tapered head machine screws. i also explained how the old #29 style curved magnet would make small conversions with a skew very useful for helping to defeat the cogging issues which have always been a problem to deal with. Kenny Dyal, the supplier on E-Bay known as "tropical_son" took my ideas to heart and had them made. they have greatly helped my efforts to develop a good motor conversion. Thanks Kenny!!
the rotor has a total of 24 mags (N40 grade). they are zinc coated and then epoxy coated. you must be careful mounting them as the epoxy coating is very tender. just my opinion, but i think they would also be great on dual rotor gennys with no need to use a resin filler around the mags.
i painted the ends of the rotor, and also the new shaft to stop any future rusting. i made a few scratches on the mags while installing them, so will also give the whole rotor a good coat of clear high heat engine enamel. for the first, i assembled a rotor and didn't get even one blood blister. LOL!
here are the pics.
the next step is to install a new set of bearings. this rotor has a 6307 bearing on the drive end and a 6206 bearing on the opposite drive end. next thing after that is to install a one turn test winding, do a lathe test to gather data to calculate the new winding.
hope you enjoyed the update! :)
zubbly |
173 Scoop users have viewed this posting.
