| Ok, I have three questions.
First question. I notice on several of the articles on this website that it is common to use 12 magnets in wind or hydro project. Interesting to see that some of the designs only have 9 coils. How come? Why not one coil per magnet? Is it because the coils are bigger than the magnets? Could the magnets be spread further apart to allow for more coils? I presume you can get more power with more coils.
Second question: When wiring a generator in star or delta configuration a Bridge Rectifier can be used to convert AC to DC. The problem is that there are 3 wires coming out of star or delta and only two wires going into the Bridge Rectifier. A person could use two Bridge Rectifiers I supose, but what do you do with the four wires coming out of two Bridge Rectifiers? Connect them together? How do you wire 3 phase to a Bridge Rectifier?
Third question: I am considering building a waterwheel type design with (24) 2 x 1 x .5 N40 magnets. I think it makes more sense to put the magnets further out on the water wheel because the speed will be faster than trying to double up the magnets and move them closer in towards the center of the circle. Does that make sense? And can there be a 24 mag / 18 coil arrangement? I presume the wiring for star or delta would run to two coils instead of one. Or could be double the wires?, would that be 6 phase?
Answers are much appreciated.
Travis |
105 Scoop users have viewed this posting.
