Finally got my 3hp 3phase motor back together again and it seems to work. There is very little cogging and I can turn it with two fingers. There is a slight tug-tug-tug as I rotate the shaft but if I turn it fast there is no cogging.
In the 1 wye connection I can get a voltage reading of 50 volts with a quick turn of the shaft, and can get a 100 watt light bulb to glow. It does the same on the other phases, so it should all work. I will be testing it at a constant rpm from 200 to 800 rpm's using the 4 different wiring combinations and will post the results.
I plan on using this generator for hot water heating. My question is, when testing the generator do I need equal loads on each phase or can I test it using one phase only. I have a 240 volt,1500 watt, and a 4500 watt water heater element that I plan to use for testing.
Another question I have is, what would be the maximum RPM of a 12 to 14 foot diameter blade before it starts flying apart? That's the diameter that I'm thinking of using.
Motor specs.
3hp 3phase
1750 rpm
8.6 amps at 240 volt
4 pole
12-.75 inch diameter .375 inch thick Grade 45 neos per pole with 10 degree offset
One more question then I'll be finished.
When testing how many amps can I safely go to before I start overloading the motor. The motor before conversion drew 2064 watts per phase so does this mean I can load it to this level or isn't this possible?
Thanks for any comments and will keep you posted on my progress!
windy |
124 Scoop users have viewed this posting.
