| If you are charging two batteries set up in parallel, will they always see the same charge current? Say you had a charger capable of delivering 20 Amps, do the two batteries get 10Amps each or will one see a higher current (if it has a different charge for example)? I guess this has to do with the impedence of a battery and how that varies through the charge cycle.
Another question - how often do batteries go closed circuit? |
79 Scoop users have viewed this posting.
