How many turns can I get?
By mettleramiel, Section Wind
Posted on Wed Jul 12th, 2006 at 02:13:22 AM MST
looking for advice
ok, so I am making a rotor with 9 coils with an inside diameter of about 1" and I would like to know about how many turns could I get out of each coil with 6lbs of #13 AWG magnet wire. Looking at the spool (which I just got today) I am thinking that I can get the 80 or so turns that I originaly intended for, but I'd like to ask some of you guys so as I don't get to one last coil left and run out. Thanks!
How many turns can I get? | 2 comments (2 topical, 0 editorial)
Re: How many turns can I get? (3.00 / 0) (#1)
by Flux on Wed Jul 12th, 2006 at 01:09:06 AM MST
4.7 lb of your wire should be about 100yds, so your 6 lb should be about 127 yds.
If you can make an estimate of the mean length of your turn you can check. You haven't given enough details but I suspect you can do it.
Re: How many turns can I get? (3.00 / 0) (#2)
by mettleramiel on Wed Jul 12th, 2006 at 07:09:38 AM MST
thank you very much! knowing how long the spool is is just what I needed!
  98 Scoop users have viewed this posting.
· Also by mettleramiel
