| I found this dump load controller on the internet a while back and cannot seem to find it again. (Would like to give credit where credit is due) I had to draw this on ms paint as I'm not at the computer where I saved the file. There are actually 3 more 3055s and 1 ohm resistors in the circuit. The problem I'm having is that the output of the op amp only goes down to about 1/2 volt. As you adjust the 1k pot to a certain value, the voltage suddenly comes up which turns on the 3055s and loads up the battery. That part is working but since the 741 output stays at about 1/2 volt when the 3055s are supposed to be off there is a small constant load and the 3055s are heating up. I am working with a 12 volt system.
My question is, can the output be made to go to zero on this circuit or at least low enough to not turn on the 3055s?
Thanks for any help.
billymc |
118 Scoop users have viewed this posting.
