lister-petter diesel 6.5hp
By pepa, Section Diaries
Posted on Fri Aug 04, 2006 at 06:36:27 PM MST
new toy
thanks to an alert from rogerAS, i now own a 1992 model lisrter-petter diesel with a metered total of 660 hrs. run time on it. the army paid $4,441.o1 and sold it to me for $210.00, mounted on a trailor with a 20gsl. fuel tank. the unit was used as a field shelter ground heater with thernostat control and electric start. the heat exchanger has been removed to make it inoperable as a heater but all other parts are in place. i intend to drive a 240 amp amblance alternator with it as a backup for my battery system but, i have several projects i am playing with and who knows where it will finish up. i can rebuild small gas engines and have not worked on a diesel before, so i will be needing help if i get in trouble on this one. if anyone has a sorce of headgaskets and other parts for this motor, i would like to have the contact info. thanks. pepa
lister-petter diesel 6.5hp | 8 comments (8 topical)
Re: lister-petter diesel 6.5hp (3.00 / 0) (#1)
by Nando on Fri Aug 04, 2006 at 01:47:48 PM MST
With 660 hours You do not need re-building, just clean it and run it
Nando
Re: lister-petter diesel 6.5hp (3.00 / 0) (#2)
by RogerAS on Fri Aug 04, 2006 at 01:58:57 PM MST
Pepa,
You're more than welcome. I agree with Nando that this engine should not need rebuilding anytime soon. I understand your wanting a source for parts. Even good engines will need some help from time to time. I will see what I can find and get back to you.
Is there a model # on the engine and serial # too will help.
Keep an eye on the run time for oil changes and you should be good to go for over 5,000 hours, maybe more, before an overhaul is needed. I have a cheapo hour meter on mine to watch that closely. My Kubota wants new oil (non synthetic) ever 100 hours. I'm not too sure about this engine.
Enjoy and keep us updated as to how it works for you. BTW I gave $250 for my Kubota, and I had to change heads, flywheel, fuel delivery system and a few other bits. The Kubota is also millitary surplus. So far mine is better than I could have hoped.
Take some pictures of the engine when you get a chance. I really wish I had been close enough to get one of these as they had several if I remember right.
RogerAS
Roger AS
9 Years off-grid & counting
Re: lister-petter diesel 6.5hp (3.00 / 0) (#4)
by RogerAS on Fri Aug 04, 2006 at 05:03:03 PM MST
Peppa,
Opps, missed the meter already onboard. Cool!
Try these guys in PA, although I suppose just 'cause it was in PA doesn't mean you are.
Hoover Diesel Service
Tel. No:
Fax: 717-656-3322
717-656-4022
they are listed on Lister-Petter web site which is,
http://www.lister-petter.com
they have a search function so you might find out anything you want.
Is it this engine?
Yep, swiped the photo from ebay. Will remove when thread dies or sooner???
RogerAS
Roger AS
Re: lister-petter diesel 6.5hp (3.00 / 0) (#3)
by Bruce S on Fri Aug 04, 2006 at 03:29:43 PM MST
Hello pepa;
  let me know what the Mil=spec numbers are on it and I'll see if I can get you the entire FSM ( field service manual) for it.
Our youngest is in H.E.M. repair and has access to even the old manuals I used to use.
BTW: If this unit doesn't have a water glass for the fuel inlet on it, get one.
Also most of the time these units sat out in the worst weather.
I am sure you already checked but take a look at the oil and filters. The 63C10's were bad about not changing them and letting water sludge build up.
Great find!!
Re: lister-petter diesel 6.5hp (3.00 / 0) (#5)
by dozer on Sat Aug 05, 2006 at 12:35:10 PM MST
Bruce,
Could you contact me via direct email?
I have a vintage Marine Corps unit, also Lister-Petter; that I need docs on.
metal at fullwave dooooot com
thanks!
Richard
Re: lister-petter diesel 6.5hp (3.00 / 0) (#6)
by pepa on Sat Aug 05, 2006 at 03:44:49 PM MST
thanks bruce, i posted another diary post with pictures and all the info i could find on the unit. i have a serious problen posting pictures but they are in my upload file, thanks pepa
Re: lister-petter diesel 6.5hp (3.00 / 0) (#7)
by Shadow on Sun Aug 06, 2006 at 12:07:33 AM MST
http://www.diesel-electric.us/  These guys have alot of Lister parts, not sure if yours is too new or not.
Re: lister-petter diesel 6.5hp (3.00 / 0) (#8)
by pepa on Sun Aug 06, 2006 at 07:52:53 AM MST
thanks shadow, i have filed their sight for future needs. pepa
  117 Scoop users have viewed this posting.
· pepa's Diary
