Zubbly, your presence is requested for some help, please.
By nanotech, Section Homebrewed Electricity
Posted on Mon Sep 11, 2006 at 06:36:57 PM MST
Seems I have another possible conversion donor.
Hi, Zubbly.  Sorry to be another to pester you again for more info, but I guess that's what comes from being the board expert on these type of things, huh?  :)
Anyways, got a donor motor here and was wondering what you thought of it.
AO Smith Mod # P48SW6V2
  1. /4 HP
  2. RPM
  3. 9 Amp
  4. Phase
  5. Hz
Is it any good for a small conversion using my little 3/8" X 3/8" magnets?  Or is this another one that'll be too much of a PITA for what I'll get out of it?
I haven't even ventured to open it up to see what would be involved in turning down the rotor to fit the magnets, just wondering what you thought of it before I even dig into it.
Thanks for any help you can offer.  I really appreciate you folks giving me advice, even if it is to tell me I'm being crazy!!  :D
Zubbly, your presence is requested for some help, please. | 2 comments (2 topical)
Re: Zubbly, your presence is requested for some he (3.00 / 0) (#1)
by zubbly on Mon Sep 11, 2006 at 04:15:23 PM MST
hi Nanotech,
i sure do think that 3/4 hp 6 pole motor will be worth converting. open it up and have a good look inside. post some pics later if you can.
a good job on it should net you 500 watt in a good strong wind. i have done 1/2 hp conversions that did produce 500 watt.
keep this in mind also. since it is 3/4 hp at 6 pole, the lamination set would be close to the equivalent of a 1hp 4 pole machine. so it has good potential.
most of my smaller conversions use the 3/4 round by 3/8 thick mags. i see no problem using the 3/8 wide mags. just be more holes to drill and the 3/8 diameter may even make it easier to get the mag pole width you want.
go for it!  :)
zubbly
Re: Zubbly, your presence is requested for some he (3.00 / 0) (#2)
by nanotech on Tue Sep 12, 2006 at 06:20:59 AM MST
Kewl!!  Thanks for the advice.
Guess I'll be turning into Frankenstein once again!!  :)
Pics to follow.  (after work, of course)
__________________________________________
My ship finally came in, but it was the Kobayashi Maru!
  94 Scoop users have viewed this posting.
· Also by nanotech
