Bad magnets (or bad design?)
By scoraigwind, Section Homebrewed Electricity
Posted on Fri Sep 8th, 2006 at 09:29:31 PM MST
These magnets are in trouble but why?
Having some grief with Nirvana machines lately once again.
You can find some history of the nirvana project on my site at http://www.scoraigwind.co.uk/nirvana
The machines were running a few years with laminated alternators but lately I have used axial flux.  We have had a lot of problems with these two machines over the years one way and another but they are great and I am building one for myself too.
OK the latest thing was a rubbing noise that I had to check out.  Turned out ot be lumps in the magnet rotors touching the stator and presumably causing some arcing at the high voltage involved.
Magnets were swelling with corrosion/(hydrogen decapitaion ?) under the polyester/glass layer and bulging into trouble.   Hunting about I found about 8 magnets out of 56 that were in this mode.
I cut them out quite easily and this is what they look like.  The problem seems to start at the corners facing the coils.  Yes I know there was some mild rust in the steel plate and that worries me a bit (always has) but this magnet failure is a very short term (under a year) breakdown on the outer face of the magnets rotor.
Possible causes:
Bad manufacture (possible)
damage during assembly (would have to be wrenches after glue and before resin)
Poor resin job (it has bubbles in it for sure)
WAter ingress and high voltages
excessive vibration (for some reason these rotors are prone to growling
Whatever is going on is news to me because I have plenty of much older stators without this problem in action on lower voltage systems and one at 100 volts.  I am bothered because I do not know what is going on.  the magnets fail thout breaching the polyester coating noticably but there is a bit of a build up of rusty swarf around the edges of all the magnets.  Maybe an excess of fine steel dust in the air gap has produced localised arcing to the magnet corners...  in the rain.
Obvously there is much talk of epoxy and probably we will indeed use epoxy next time.  I reckon it cost 4-5 times as much.  And we like to totally immerse the magnets here, so there will be a lot of epoxy.  But will this really address the issue?  Dan does not cover his magnets and he has not seen this failure(?)
As you can tell I have my ideas about this but am very interested in hearing more ideas.  We don't like our magnets to swell up and burst into the stator in under a year.  It's not acceptable.
Bad magnets (or bad design?) | 46 comments (46 topical, 0 editorial)
Re: Bad magnets (or bad design?) (3.00 / 0) (#1)
by vawtman (vawtman(at)charter(dot)net) on Fri Sep 8th, 2006 at 04:10:44 PM MST
Hello Hugh
 Could it be electrolisis thats causing this .i know unbonded stainless steel in a saltwater environ will corrode if not coated but if its bonded to a ground source like a panel nothing happens.Just a thought
 If one tinsy crack developes the rust will make more and more.
 Im sure ill get shot for this but like i said just an opinion.
Re: Bad magnets (or bad design?) (3.00 / 0) (#46)
by brkwind2 (mcool61@nspamyahoo.com) on Fri Feb 8th, 2008 at 10:43:06 AM MST
Wouldn't the ground path have to travel through the bearings?
"I get along with all people despite their shortcomings of race, religion or orientation. So long as they recognize my superiority we'll get along fine." "O
Re: Bad magnets (or bad design?) (3.00 / 0) (#2)
by DanB (danb@*no spam*otherpower.com) on Fri Sep 8th, 2006 at 04:26:35 PM MST
Hmm...  you live in a place where there are no trees, lots of salt spray, it's cold... and most unfortunate... magnets come apart there.  It sounds uninhabitable!  (I'd move) ;-)
Re: Bad magnets (or bad design?) (3.00 / 0) (#7)
by DanB (danb@*no spam*otherpower.com) on Fri Sep 8th, 2006 at 07:44:45 PM MST
Just kidding really.
I noted what zubbly said though - it does look like stuff is rubbing on lots of the magnets.  I have to wonder if maybe slight rubbing didn't first damage the magnets then this happened.  We're in a dry climate so it's hard for me to say - but I've not seen this sort of problem at all unless the magnets were first damaged by rubbing on the stator.  The one on Guemes Island looked sort of like that too - but it had a problem with rubbing on the stator.  When the stator warped on my 17' machine and we continued to run it - a similar problem happened.  Some of the magnets had their plating damaged and were starting to rust.
Someone mentioned the hydro plant we made for Scotty, I think that was 2.5 years ago.  On that we have a rediculous airgap (to bring the speed of the alternator up) so there is no chance of the magnets ever rubbing on the stator - and those magnets are wet all the time and we've not had problems yet.
I've been wondering lately if it's not worth using somewhat thicker/larger magnets than we really need in order to provide for a 'safety factor' here.  I wonder how much simple things like temp change etc... affect the 'flatness' of the stator.
Last week I worked on (replaced one) a couple older machines we used where we had lots more magnet than we needed and I had the cutin speed too low so we wound up opening the airgap - perhaps about 1/8" - 3/16" on each side of the stator.  Those are so wide they've never scraped - and those magnets were never covered with resin, they've always been exposed.  Those magnets still look like new, the machines were both over 3 years old.
I've never seen magnet damage of any kind yet except on machines that had a rubbing problem.  I think the larger we go in diameter, the more a safety factor we may need because a little play in the bearing will result in more clearance required as the machine gets larger in diameter.
This may not be the issue but it's my first thoughts on it...  Next time you put the machine up, slap a spare magnet on the side of the tower and see how it holds up by itself in the weather perhaps.  I've had lots of NdFeB magnets laying around outside up here for years (Again - in a dry climate) and the plating seems to hold up fine.
Re: Bad magnets (or bad design?) (3.00 / 0) (#3)
by ghurd on Fri Sep 8th, 2006 at 04:45:01 PM MST
Hi Hugh,
"very interested in hearing more ideas"
Just my experience.
Dan is in a dry area.  I am not, but I don't have any salt air.
Lots of PMAs in my very damp, sometimes weeping or flowing, cellar. Many with uncoated magnets or partially peeled chrome hard disk magnets.
They were glued down with slow cure, water proof, grocery store purchased, 2 part epoxy, then heavily coated with left over epoxy, something like painted with paste.
Most were not subjected to rapid or extreme temperature differentials.  Some were, but not many cycles.
Most are induction conversions or similar.
I put a lot of effort into totally coating the magnets as they were placed.
The worst ones have been down there for over 3 years.
No visible rust as far as I can tell.
A couple have epoxy separating from the rotor ends, but I suspect it due to improper rotor surface preparation.
Some without protection, or damaged protection, are not usable. And I believe they have not been in "The Dungeon", as my wife calls it, as long as a few of the older PMAs.
These are pretty typical for what I do.  A necessary evil to understand what I am saying.
It is offensive. Sorry.  :/
http://www.otherpower.com/images/scimages/2050/3phHD.jpg
http://www.otherpower.com/images/scimages/2050/FanArm.jpg
Re: Bad magnets (or bad design?) (3.00 / 0) (#6)
by electrondady1 on Fri Sep 8th, 2006 at 07:39:30 PM MST
i think there are a few things happening here . electrolisis, probably. if it were just a few mags being corroded you could chalk it up to a manufacturing flaw, but all the mags show signs . it looks from the photo as though there is consistantly more corrosion on the outside edge of the mags than towards the center.
Re: Bad magnets (or bad design?) (3.00 / 0) (#8)
by DanB (danb@*no spam*otherpower.com) on Fri Sep 8th, 2006 at 09:14:42 PM MST
Perhaps electrolysis is an issue - Ive not had problems myself (unless things are rubbing in which case there is a problem every time).  I don't know a lot about electrolysis but Nickel Iron batteries come to mind...
I've been using epoxy coated magnets off and on... maybe thats a better way to go but Im not sure.  It would be nice to find the real root of the problem, I hate solving problems that dont exist.
Polyester and other resins have been discussed a bit lately.  It's been brought up that polyester is not water proof.  Perhaps moisture is getting through the thin coating over the tops of the magnets and staying in there.  Hard to say... my guess is still that Hugh's problems here are mechanical - something is rubbing.  Could be wrong...
Re: Bad magnets (or bad design?) (3.00 / 0) (#42)
by Slingshot on Mon Sep 11th, 2006 at 02:27:09 PM MST
Ghurd, I'm confused.  The last picture you linked shows the magnets on opposite sides of that rotor marked as having like poles facing out.  What's up, was it an odd stator arrangement?
Re: Bad magnets (or bad design?) (3.00 / 0) (#43)
by ghurd on Mon Sep 11th, 2006 at 03:21:48 PM MST
It sure is an odd stator arrangement!  A 4 magnet, 6 coil, 3 phase, box fan.  It works...
as long as the magnets do not get TOO good. Then it coggs.
Anyway, the magnets are uncoated neos, covered in waterproof epoxy. Sat in the wet cellar for over a year and still looks the same.
The shaft rusted, and bushings don't like rusted shafts.  I intend to rewind it with #20 wire, in Jerry-Rigged delta, eventually.
Mag Condition on Scotty's Hydro (3.00 / 0) (#4)
by Countryboy on Fri Sep 8th, 2006 at 06:47:17 PM MST
DanB built a small Banki turbine for a hydro application about 2 years ago.  http://www.otherpower.com/scotthydro1.html  It appears that he used nickel plated neos in that too.  I wonder what condition those magnet rotors are in now.  While not exposed to salty sea spray, they are in a wet environment.
Hugh, look for patterns and see if the patterns lead you anywhere.
Were magnets on both rotors damaged, or was the damage limited to only one magnet rotor?
Did the damaged magnets all have the same pole facing the stator?
I would also try passing a current through the stator.  Lay a magnet on the stator, and slide the magnet around on the stator, while holding a multimeter lead on the magnet.  That way, you can check to see if the stator is arcing anywhere.  You may want to wet down the stator to see if that affects anything.
My gut tells me that the magnets rubbing on the stator damaged the nickel plating, giving the corrosive sea water spray an entrance into the magnet body.  (which would explain why the side of the magnet closest to the stator corroded first.)
Re: Bad magnets (or bad design?) (3.00 / 0) (#5)
by zubbly on Fri Sep 8th, 2006 at 06:56:45 PM MST
(User Info) www.zubbly.com
hi Hugh,
ok, my thoughts since you asked  :)
first, i see on every magnet, radial scrub marks. i think eventually all the magnets will fail the same way. with the unit assemble with only one magnet plate on, i suggest rigging a dial indicator to determine the trueness of the mag plate. very slow rotation by hand will allow you to see just how much the plate runs out. also, with loaded torque, it may be bending more and allowing mags to scrub the surface of the stator. a possible larger air gap may be needed to ensure no rubbing during operation. a few extra turns in the coils may help offset the drop in voltage from an increased air gap.
the growling that you hear may be typical of strong electrical noise associated with having many many poles in the machine. the growl does not affect performance, but just makes noise. a possible cure for this, as is commonly done in high pole induction motors that also share the same problem, is to connect each phase "skip pole".
normaly in the phase, one coil is connected to the next coil (adjacent pole) and your jumpers from coil to coil are connected from an end of one coil to the beginning of the next coil.
in skip pole, you do not connect to the next coil in the phase, but skip that coil and connect to the next one. your coils then connect from the end of the coil, to the end of the coil, and from the beginning of the coil, to the beginning of the coil.
this method completely eliminates the growling in high pole induction motors, but am not sure if it will cure the noise in a coreless machine.  just thought i would mention it as a possible cause and cure.
zubbly
Re: Bad magnets (or bad design?) (3.00 / 0) (#9)
by RP (russp located-at fidnet (dot) com) on Fri Sep 8th, 2006 at 10:23:10 PM MST
On the rubbing:  In cold temperatures could the bearings be shrinking a bit and allowing more "slop" in the rotor?  Is there a pattern in the brand or type of hub assembly or bearings in the units that fail this way?
Re: Bad magnets (or bad design?) (3.00 / 0) (#10)
by Flux on Sat Sep 9th, 2006 at 12:56:32 AM MST
This does seem to the big downside of neo. Much more worrying than its temperature limit.
Fine for our friends in N.America where dampness is not a big issue in many areas but it does bother me here where everything rusts away despite all the clever magic coatings that never work.
I think you can rule out electrolysis, if there was any effect it would be between the steel and the magnets, and it doesn't happen unless there is moisture which is the problem anyway.
Hydrogen decrepitation can't be ruled out, it is never certain what products are released from plastics and there will undoubtedly be ozone and other things in the presence of electrical fields and who knows what this does to other materials.
The big issue is moisture, electroplate is not waterproof, nickel is one of the best but not foolproof even if never damaged.
No resin is waterproof, it is a matter of how bad, polyester is the worst but I suspect mainly from small cracks rather than the material itself. Polyester electrical varnishes come out quite well but are a different formulation and are not carried in styrene.
All my magnet rotors are showing signs of rust stains round the magnets under the polyester so it is a matter of time.
I notice concentric scratch marks on your magnets and I am fairly certain that that is the starting point for the trouble. To me these don't look like rub marks, they aren't bad enough and I am wondering if there were small magnetic particles on the magnets during assembly, mine almost always have some and these may be scratching things over time. Also with big machines I wonder what grit, dust, twigs etc pass through the air gap over a period of time and cause more scratching.
I have slowly come to the conclusion that casting the magnets completely in resin doesn't prevent rust, it slows it but is a costly way to slow it.
For some time I have thought of bonding thin glass fibre epoxy insulation board on to the face of the magnets. This commercial stuff is far better than any coating of glass and resin applied cold and is also very tough and will resist abrasion very well.
Not sure what you do with the rest of the magnet. I suspect a fairly thin coat of urethane or similar that is flexible may be better than brittle resins.
Some of the Belzona repair materials would no doubt be excellent, their products often actually do what they claim and that is unusual but as always they cost the earth and are difficult to get in small quantity.
Perhaps we need to get the food industry to make us some vacuum formed plastic covers for the magnets and bond these to the steel plates and keep hydrogen damp and everything out.
Not sure of the answer at the moment but I suspect the bigger the machine the bigger the problem.
Re: Bad magnets (or bad design?) (3.00 / 0) (#11)
by scoraigwind (magnet@scoraigwind.co.uk) on Sat Sep 9th, 2006 at 12:58:52 AM MST
(User Info) http://www.scoraigwind.co.uk
Hi and thanks for all the feedback so far.
Electroysis I do not think so.  As I understand electrolysis this is something that occurs under water when you have two different metals touching - such as copper and steel.  The baser one of the two metals corrodes.  In this case yes, the steel disks are corroding, but not seriously, and the real problem I have is with the cu-ni-cu plating on the magnets becoming ruptured, letting in moisture that ruins the magnets.
Rubbing yes I do think this is very noticable on this alternator and it brings me back to the thing about such a lot of swarf around the edges of the magnets too.  These are factors I do not usually see, or only to a small extent.  Maybe this machine was dirtier than usual.  The bearings do seem a bit loose and some rubbing is certainly possible.  Some of those marks will have been made during assembly, and the air gap is my usual (about 1.5 - 2 mm is my minimum gap).  The stator does show some signs of abrasion too, but on one side it has not reached the copper nor was there any sign of arcing on that side.
At first I only noticed the problem on one side, and the stator was by then significantly damaged in one spot so that the copper was bare and looked like it had been sparking.  I did think for a while that the sparking was the cause of the problem.  However when we had fixed all that and started to put it back together was when I noticed bulges on the other rotor - the back one.  Here there was no visible damage to the polyester coating other than some superficial rubbing marks but four of the magnets were starting to bulge noticably.  It's like the damage starts from within and moves outward.  But it does not start at the steel disk - always on an outer edge of a magnet block.
My concern is that I still do not understand what damaged the plating on the edges of some of the magnets.  Not direct impact for sure (unless it occurred during assembly before the polyester covered them).  Maybe some sort of arcing via swarf build up at the magnet edges.  But I am surprised that the stator did not show more blackening if this were the case.  On one side the stator looks quite normal.  Some scuffing, sure but nothing to indicate arcing and sparking.
I like to embed magnets in resin and glass fibre for a couple of reasons.  One is to protect against scuffing and knocks during assembly and when stuff gets into the air gap.  In this case it seems to have failed.  Another reason is to securely support the magnets agains centrifugal force. Maybe this is unnecessary paranoia.  If I were to use epoxy then a third reason would be to keep moisture away from the magnets too.  Maybe as Dan says I should just use thicker magnets and a wider air gap and skip the covering of resin - just glue them to the disk.  On that subject, by the way I believe that the best adhesive for this is BONDMASTER F246 (a surface-activated structural acrylic adhesive).  I would use stuff like this except that I am drawn to low tech solutions where possible.  Maybe this is nonsense when using Neo magnets since they are already pretty high tech, but I like to use materials that are easy to find all over the world when I can.
Thanks for all the discussion and I hope to hear from others in due course if anyone has more ideas.  Flux does not seem to be out of bed yet?
It's all good fun, but we like our magnets to stay shiny and bright so I am a bit upset by this.  It's not what I am used to at all.
Re: Bad magnets (or bad design?) (3.00 / 0) (#34)
by vawtman (vawtman(at)charter(dot)net) on Sun Sep 10th, 2006 at 01:01:47 PM MST
Hugh it looks to me that the rotors rusted where the nickel and steel were fastened and possibly causing the rubbing.Electrolisis can occur in the presence of just salt water moisture in the air then for some odd reason it is retained in the hairline cracks and spreads until the coating or structure eventually breaks down.
 Trust me seen this
 Maybe best not to use nickel coated mags.Just epoxy coatings
 If things are perfectly sealed or bonded nothing happens
 Did you notice dampness under the mags when you pulled them.
Re: Bad magnets (or bad design?) (3.00 / 0) (#12)
by willib (willibur at comcast dot net) on Sat Sep 9th, 2006 at 01:30:50 AM MST
Maybe the rust starts at the magnet rotor interface and creeps up the magnet edges till it surrounds the magnets
you may have to dislodge one of the shiny magnets from its home to tell if it too has as much rust as one of the bulged rusted ones
how is the field on the magnets overall, are the all still good ?
possibly heat has got to them ,
i guess the question is could the Ni-Cu-Ni coating on the mags be penetrated by rust or is it something else
Carpe Ventum (seize the wind)
Re: Bad magnets (or bad design?) (3.00 / 0) (#13)
by Flux on Sat Sep 9th, 2006 at 02:33:31 AM MST
Hugh
Just another thought why this may be more of an issue with the big machine.
I am not sure what power is dissipated in the plating of the magnets by the flux ripple. There is definitely some loss and it is not negligible with steel pole pieces. I assumed it was negligible for the bulk material of neos as it doesn't need much resistivity to kill it but the plating may be conductive enough to have some effect.
This would be worse with higher power and certainly much worse with frequency. If it was a significant issue I suspect those playing with large scale machines would have found it but such machines may not be exposed to damp.
I was expecting Scott's hydro machine to be a good test bed for this neo corrosion problem and it throws my thoughts off track a bit when Dan said it has shown no problem. It is worrying that wet alone may not be the issue.
Re: Bad magnets (or bad design?) (3.00 / 0) (#19)
by scoraigwind (magnet@scoraigwind.co.uk) on Sat Sep 9th, 2006 at 08:40:03 AM MST
As I already said, that backs of the magnets I took out are fine.  The corrosion is all on the stator side.  If the problem arose from corrosion of the steel disk (through electrolysis or whatever) then I would expect to find worse problems at the back than the front.
Thanks for the idea about eddy currents, Flux.  It's certainly a possibility.  Not sure what to do about it though!
Re: Bad magnets (or bad design?) (3.00 / 0) (#14)
by DanG on Sat Sep 9th, 2006 at 04:19:48 AM MST
I have read papers suggesting 2-3% of a neo mags flux energy is needed to maintain its escape of the nickle plate covering. Also have noted in papers that nickle is used primarily for its lubricant properties for ease of automated handling both on product and equipment by the manufactuors.
The corner plating failing might be attributed to disimilar heat expansion-contraction cycles, where once the bond has failed on the largest flat planes (helped by moisture intrusion?) the resin encapsulent heave literally lifts off a microflake of the corner plating that has remained well bonded - the (or all) corners having been minutely damaged during batch process handling on an automated assembly or counting machine, etc. and so vulnerable to our encapsulent shifting.
So - aside from using OEM epoxy coated neos to begin with - how about armoring the nickel-plate with a epoxy coat "dip" before encapsulating?
Also would be looking into a resin compatible primer-tackifyer for the iron, some of the recent rotor rehab pictures show corrosion "rings" similar to tree rings that show chronological progesseion of delamination across the bare metal, in my climate here in Minnesota the seperation would be accelerated by freeze/thaw cycles too...
Just a slight improvement on design? (3.00 / 0) (#15)
by Norm (peppysue@suite224.net) on Sat Sep 9th, 2006 at 06:14:52 AM MST
    To prevent rubbing at all would it be possible
to put a circular pad of teflon on top of each
magnet thinner than the air gap? At least that would eliminate the chance of rubbing...if that is
the initial cause?
    I have no experience at all in axial flux
alternators ...but  I've been thinking about the
problem  of  accidental rubbing  of the magnets
for quite some time....Maybe it's a dumb answer?
            ( :>) Norm.
( :>) Norm
Re: Bad magnets (or bad design?) (3.00 / 0) (#16)
by wpowokal on Sat Sep 9th, 2006 at 06:50:08 AM MST
Hugh just a thought, we have a duel rotor as per your book, while we have had our dramas the only fault is the plate the stub axel is mounted to.
I make reference to it cracking here
It is too thin and when we set clearences in the shed all is OK. But when we place the blades on the unit as it is on the tower to do a final tracking check, 90 degree different it rubs, but up in the air all is OK
So we will be lowering it to reinforcing this plate, is this a possible cause of your problem.
allan down under
Re: Bad magnets (or bad design?) (3.00 / 0) (#20)
by scoraigwind (magnet@scoraigwind.co.uk) on Sat Sep 9th, 2006 at 09:03:07 AM MST
Hi
That sort of cracking is probably due to excessive vibration due to a poorly balanced blade or a phase imbalance in the alternator.  And the hole is very near to the edge of a thin plate.
We have had some pretty bad vibration due to resonances in the magnet rotor disks at certain speeds but the steelwork is still good.  The guy I work with Alan likes to use heavy steel.  It may be that we could reduce the electrical vibration by altering the controls in some way (for example with capacitors).  But the vibration seems to be largely due to resonance rather than excessive torque ripple.
I have inspected the gap in situ (on the wind turbine on the tower) and it seems Ok except where the magnets have swollen, and there is is not so good.  the score marks are probably worth thinking about though.  I don't usually see that much of this sort of evidence of rubbing.  I feel that there may have been an excessive amount of ferrous debris in the gap at some point in time and this may have caused the damage to the magnets, through the layer of glass and polyester.
It could be a case of rusty particles scoring the magnet coating and then the combination of damp, high voltage and vibration producing accelerated corrosion and failure of the magnets.
Overall my plan is to
  1. Increase the air gap
  2. Be extra careful to avoid crap in the gap.
  3. Probably use epoxy resin instead of polyester for this machine next time.
Given that the magnets cost about $4 each and the polyester to set them in costs about $0.12 for polyester and $0.50 for epoxy this will not be disproportionately expensive.  It will seal out the water and bond the magnets better.
I would still want to use polyester for the stator though.  It has worked well thus far and I have learned from Dan that it cools better than epoxy (especially when mixed with talcum).  I do not have any problems with stator warpage or cracking so long as I use talcum powder and avoid putting too much catalyst or it will set fast and hot.
I am not convinced that this is going to be a problem with my standard designs - certainly I have not come across anything like it yet.  I do expect corrosion of the steel disks and I can see this being the factor that determines the life of the machine after a few years.  It might be worth considering using plated disks so as to retard the corrosion.  I am just a bit worried about the uneven surface and the extra cost and hassle.
Re: Bad magnets (or bad design?) (3.00 / 0) (#21)
by wpowokal on Sat Sep 9th, 2006 at 09:21:02 AM MST
Hugh I believe you are very correct, this plate has been there since the tripple rotor days and has therefore suffered serious inballance, long story.
I believe our last failure started with a bridge failure, thus phase inballance as you correctly sugest.
Sometimes it's the ball from left field that scores the home run.
regards
Allan down under
Re: Bad magnets (or bad design?) (3.00 / 0) (#17)
by RobD on Sat Sep 9th, 2006 at 07:55:54 AM MST
I wouldn't over look the growling. You may be getting high freq. vibration that is acting like an ultra sonic cleaner. My guess it is several things working together along with this. The high voltage certainly comes to mind.
Re: Bad magnets (or bad design?) (3.00 / 0) (#18)
by disaray1 on Sat Sep 9th, 2006 at 08:13:34 AM MST
 Here's an observation from a completely inexperienced newbie.
 It seems to me that this problem comes from a series of elements.
  First, the concentric scratches that Dan, Flux and others have noted, appear not to be the root of the failure..if so, the rust/corrosion would have initially manifested itself at those scrape areas, not at the outermost ends as it appears to be happening. The scrapes still look ok, right?     As a side note, could those scrapes be caused by the stator "growing" with heat expansion under heavy generating load, and closing your 1.5 to 2mm gap?
 Second, and since I only have one image to make this observation, this may be completely off base, but the photo shows most of the affected magnets that were cut out, on one concentrated area of the rotor...does this area correspond to a heavy spot ie. when this machine comes to rest in no wind (does that ever happen in Scoraig?), would the worst corroded area of the rotors be pointing towards the ground, effectivley making this the "moisture dripping low spot? The last area to get dry?
 Third,as everyone else has noted about polyester resin not being waterproof, it will also almost always contain moisture even after curing. Its a sponge. Now combine the sponge effect, add a little salt spray (you have that) which gets absorbed into your sponge, throw in a little nickel, chromium, and mild steel, some expansion and contraction from heat...and voi-la, you've got a perfect incubator for corrosion.
 I used to take care of an old Formula 1 car from the sixties, and many parts were nickel plated chromium steel. It would rust right in front of your eyes practically. I spent many, many hours cleaning corrosion from those parts, over and over again. And I didn't have the problem of a sponge holding salt water against those parts.   Nickel plating is porous!
 I finally got smart about it. I had them powdercoated. No more corrosion!
 Take this with a grain of salt. Like I said, I'm very new to this. I've never even held a Neo in my hand!  I'm especially grateful to even be able to post here, with all of the brilliant minds. Thank you all for your expertise, and sharing that knowledge!
disaray1
Re: Bad magnets (or bad design?) (3.00 / 0) (#22)
by pepa on Sat Sep 9th, 2006 at 10:57:30 AM MST
Very good points disarray 1, there does seem to be a variety of factors that are causing the problem. My thoughts are that we are trying to keep the air gap between the magnet surface and the stater to close. To get max power out we are holding as close as possible when the components are new and it works fairly well but- as the machine begins to wear and settle in, the gap changes by bearing slop (bearing grease settling and wear on bearings), expansion and contraction from the elements, vibration, stress on metal parts by vibration, prop torque or centrifugal force, and most of all moisture effect on the parts. Electrical current and water are mortal enemies in most situations. The coils heat and cool many times as the wind speed changes during a given time period and this has to affect the surrounding materials. Just my thoughts, pepa.
Re: Bad magnets (or bad design?) (3.00 / 0) (#23)
by jmk on Sat Sep 9th, 2006 at 11:23:33 AM MST
 Looks like the ones you removed are from one area of the rotor. When you spin it does that area run closer to the stator? Dan was putting enamel paint into his resin for color. I wonder if this will help for waterproofing too? Maybe a better paint on the outside will help. Of course if the resin gets micro cracks  while in the air it will let moister in. I would think Your solutions you mentioned will help a great deal. I would try to get all the pits filled. Make it smooth as possible with a good paint job. I liked how Dan was turning his rotors on the lathe after casting. A smooth surface will also help in freeze conditions. You could just use scratch filler and a sander. When you open the air gap I wonder if just spraying the whole rotor with that rubber stuff that Shadow is using will work. I think he said he had separation were the magnets butted the risen, but with it casted over the top it would make a better application I would think. Just a rookie point of view.
jmk
Re: Bad magnets (or bad design?) (3.00 / 0) (#24)
by zapmk (user name at zap-comp dot com) on Sat Sep 9th, 2006 at 01:30:03 PM MST
Hi Hugh,
Although I cannot comment on whats going on with the mags, I can comment on the rotors and the possible scrapes and growling.
I am in the process of building a large rotor machine myself, One of the things that I found when testing or setting up the rotors was that the pull of the high powered neos was so great, that it would actually bow the half inch steel a few thousandths. Then I took another look at your web site on the nirvana and it looked like you were using jacking screws closer to the outer part of the rotors.
When testing a test coil, I found that by putting a load on the coil (just for the fun of it), armed with two dial indicators one on either side of rotors directly across from the coil it still would cause the rotors to move a few thousandths in and out.
Then I tried the jacking screws only drill for one of the rotors, it was much better
as far as movement, but could hear a slight noise. so I drilled both rotors for the screws, and now have no movement or noise at all. I think the screws were vibrating on the back rotor.
Just a thought.
 -Zapmk
Re: Bad magnets (or bad design?) (3.00 / 0) (#25)
by free energy64 on Sat Sep 9th, 2006 at 02:50:25 PM MST
Hello, can I put forward an idea, might seem crazy, but here goes anyway.
Instead of covering and securing the magnets with epoxy or whatever, why not simply glue mags to rotor to hold in correct position, then take rotor to a place which can heat shrink a layer of plastic completely over the rotor and mags?
If say 3mm perspex type plastic was used, then the mags would be securely held in place with absolutely no way of movement and the whole rotor would also be waterproofed if silicone or similar sealant was liberally applied between the shrink plastic and the rotor surface.
If added fixing of mags still desired then screws could be placed around mags which would locally secure shrink plastic to rotor for added rigidity.
Just a thought and look forward to your feedback.
Re: Bad magnets (or bad design?) (3.00 / 0) (#26)
by hiker (hiker.wild[at]yahoo[dot]com) on Sat Sep 9th, 2006 at 04:32:10 PM MST
sounds like hugh hit the nail on the head--crap in the gap--crap in the gap caused a scracth and unprotected the mag went to crap....................
WILD IN ALASKA
jacking screws (3.00 / 0) (#30)
by scoraigwind (magnet@scoraigwind.co.uk) on Sun Sep 10th, 2006 at 12:54:29 AM MST
We could almost start a new thread on the subject of jacking screws.
We did experiment with using jacking screws in place permanently to stiffen the magnet rotors and reduce the bending.
First time we tried leaving the screws in place it was fine until it reached a certain speed, and then it made an appalling noise.  The screws were vibrating on the plates.  We took out the screws.
Next time we arranged it so the screws were locked onto both plates front and back with nuts.  Unfortunately we still got some fairly loud noise this way too.  I do not really understand why.  We removed these screws too.
You might think that stiffening the disks with jacking screws would reduce the chances of resonance but in fact they seem to bring the resonant frequency up to a bad range where the machine gets rather noisy.  since they were a solution to a problem that did not rally exist in the first place I tend to avoid using permanent jacking screws now.
Re: jacking screws (3.00 / 0) (#41)
by BigBreaker on Mon Sep 11th, 2006 at 11:36:13 AM MST
Some very skilled machinists have cut a port and channel through a stationary rotor spindle.  This allows the stator to be fixed to the stationary spindle and the stator wires to be brought out through its center.  The rotor plates rotate on separate bearings which are supported by the stationary spindle.
Because the support for the stator comes from the center, the rotor plates can be bolted together on the outside.  This is a much stronger topology and I can't imagine a resonance developing.  The rotor simply can't "flap" when supported on the outside.
Re: jacking screws (3.00 / 0) (#44)
by scoraigwind (magnet@scoraigwind.co.uk) on Mon Sep 11th, 2006 at 04:30:30 PM MST
The hollow shaft is not too hard to do but I do not recommend mounting the stator centrally like that.  Machines I have seen built like that suffer from frequent failures of stator mounting.
It would be nice to enclose the machine from some points of view, but cooling is pretty important if you want to get the benefit of stronger winds and kick out power, so it really does make sense to keep the structure open and to weatherproof the parts.
Re: Bad magnets (or bad design?) (3.00 / 0) (#27)
by windstuffnow (elenz(at)windstuffnow(dot)com) on Sat Sep 9th, 2006 at 05:54:23 PM MST
  I've had a few magnets that ended up like that as well.   I had noticed on a couple smaller machines when I had used super glue some of the plating bubbled up.   I wonder if the MEK in the resin is causing some type of breakdown.  Seeping into tiny pours of the metal.   Could be simply a poor plating job or the internal material had already started to corrode prior to plating.
Have Fun! Windstuff Ed
Re: Bad magnets (or bad design?) (3.00 / 0) (#28)
by stephent on Sat Sep 9th, 2006 at 06:50:20 PM MST
Are you using talc for a "filler" in the mag casting?
The words "hydrated magnesium layer silicate "
and "Alkaline magnesium silicate " come to mind here.
Looks like a coating of rust all around magnet outlines in the pictures.
Resin is porous and the talc is a good water holder, small plating defects in the nickel can lead to this quickly in the presence of salt water.
Looks like a combination of elements at work--heat expansion--resin porousness and thermal expansion differing rates (cracking at mag outlines)--and a water holding combination at work.
And of course the scratches over a time didn't help much either with water getting into the mag area.
Just shocking/dropping/hitting a Neo/ceramic mag will make a small fracture that the plating could be holding together, that could eventually seperate a bit and with water---??
You have a difficult environment to keep even a good powder coated or epoxy coated steel object safe in, let alone a Neo magnet (they could be called a "rust" magnet.)
Re: Bad magnets (or bad design?) (3.00 / 0) (#29)
by willib (willibur at comcast dot net) on Sat Sep 9th, 2006 at 11:25:50 PM MST
i agree with Ed and stephent tiny holes in the plating ( Bad magnets ?) and scratched up fiber glass , which will also hold moisture , may have led to the rust surrounding the mags.
aside from the benefits of cooling , what about some sort of cover or shroud , over the alt ? to protect it from the elements
Re: Bad magnets (or bad design?) (3.00 / 0) (#31)
by WXYZCIENCE on Sun Sep 10th, 2006 at 02:01:50 AM MST
Hugh,
I had some round plated neos do the same thing. They were attached to one of my cutting machines and the humidity was very high. I think the quality of the neos is part of the problem. Maybe too much hardener in the resin, this generated heat, trapping condensation between the resin and the neo. This could also explain the corrosion. Joe
Re: Bad magnets (or bad design?) (3.00 / 0) (#32)
by Murlin on Sun Sep 10th, 2006 at 08:05:55 AM MST
I haven't posted in a while and so I thought I might as well throw in my 02.....
All the magnets I just bought have burrs on them that were left by the grinding belt that was used to champher the blocks when they came off the surface grinder.... I cannot see any signs that these blocks were put in a deburring machine before they were plated.
Could it be possible that some of the tiny knife edged burrs are being broken off and leaving holes in the plating?
Could it be that the salt water that is finding its way in the pocket with the magnet, is accelerating the oxidation process?
Murlin
Re: Bad magnets (or bad design?) (3.00 / 0) (#33)
by powerbuoy on Sun Sep 10th, 2006 at 10:50:32 AM MST
Tons of post on this issue ...wow. I am actually convinced that you are dealing indeed with electrolysis. (like VAWTman said earlier)It might be surprising, but for a example a stainless steel plate is capable of creating an electrolysis problem in itself if the surface area gets damaged. The result looks like rost, but is truly an electrolysis which will spread out over the entire plate. You will actually receive straight marks too ... How can that happen? It does not have to be mechanical damage. Bird poop will do the trick. Anyone who starts laughing at me now may perform the following test. Take a SS plate, put some birdfood on it, leave it outside and wait a couple weeks ... surpriseeee.
It would not be the first wind turbine that might have been visited by our feathered friends ...
Powerbuoy
Re: Bad magnets (or bad design?) (3.00 / 0) (#35)
by Flux on Sun Sep 10th, 2006 at 02:31:38 PM MST
Yes when electrolysis was originally mentioned I thought that the issue was between the magnets and steel plate. You are almost certainly right that electrolysis forms part of the breakdown  of the magnet once the nickel plate is damaged in any way.
The iron component of the magnets rust due to moisture. there are more complex disintegration processes within the sintered structure of the material including electrolysis between the components, adding the nickel into this makes things worse.
finally any form of electrolysis in the presence of most electrolytes will result in hydrogen decrepitation.
The only satisfactory solution is to produce some completely waterproof coating and make sure it doesn't get scratched. Not an easy challenge.
You fellows that live in dry climates don't know how lucky you are.
flux
Re: Bad magnets (or bad design?) (3.00 / 0) (#36)
by elt on Sun Sep 10th, 2006 at 03:40:06 PM MST
I've been holding off mounting my magnets and doing a lot of googling in response to the ideas and problems presented in this thread. I'm no chemist but it looked me like it just takes nickel, water and current to start electrolysis. I don't know eddy currents from lazy susans but its seems that if a few tenths of a volt can be induced on the surface of the nickel then nickel ions will move if there is water present...
I've read a bit in this thread and others reading of magnets coming loose, diodes popping and coils cooking ... even making the mill myself, I'm looking at a couple of years of payback and if life expectancy is only two or three years that's only a push and it's a bit expensive for me to invest in. It seems that many people are having good luck though so I's still hopeful.
Based on what I've been reading (and thanks to everyone that shares both the good and the bad) I'm thinking:
  1. gluing the magnets with lokitite, something like 620 or 272 (which I believe are acrylic adhesives.) Weatherproof and good for -65F to 450F.
  2. weather proof with epoxy and silica filler. This makes a very hard surface that I think will give good wear resistance. Silica filled epoxy also feels more slippery to me so hopefully that will help clear out any trash that gets in there.
  3. I won't fill in between the magnets. If anything gets between the magnets and stator hopefully it will go into the gap and get ejected instead of making long scratches like I see Hugh's picture.
  4. Will make some sort of sheet stainless weather shroud to go around top and side of the alternator (using the three stator mounting studs) to help shield a bit from the weather.
None of that is based on my "expertise", only my interpretation of the most conservative approaches suggested by others.
 - Ed.
Re: Bad magnets (or bad design?) (3.00 / 0) (#37)
by scoraigwind (magnet@scoraigwind.co.uk) on Sun Sep 10th, 2006 at 03:48:33 PM MST
OK yes after the fact when the magnet is wet inside then electrolysis is probably at work along with all kinds of bad stuff.  I don't really want to find ot more about that.  I want to keep the magnets dry inside.
The funny thing is that I have plenty of machines in this climate working fine without this problem.
I feel that the scoring is the key, as flux and others point out.  Maybe the high voltage and vibration and possibly temperature play some part.  But I don't see the magnets getting very hot at all with that well cooled disk and the air gap.
Increased clearance, and cleaning of parts should solve this one.
For a really durable solution I suspect we need galvanised magnet rotors and some sort of impermeable resin encapsulation.  But we are talking about quite a few years before you would notice, based on my experiences.
Re: Bad magnets (or bad design?) (3.00 / 0) (#38)
by DanB (danb@*no spam*otherpower.com) on Sun Sep 10th, 2006 at 06:03:34 PM MST
It's possible that epoxy coated magnets are the way to go.  Manufacturers tell me they resist corrosion the best - but they do scratch more easily.  Polyester doesn't stick to anything that well, but it seems to stick to the epoxy magnets as well as anything else (if not better) and I believe I've given up on polyester for magnet rotors anyhow.  I've had a few machines with polyester rotors that are holding up fine - I've had a few really obnoxious failures too.
Re: Bad magnets (or bad design?) (3.00 / 0) (#39)
by electrondady1 on Sun Sep 10th, 2006 at 07:24:28 PM MST
i'm still experimenting with harddrive neos and from cuting them up, one thing iv've found is there is very little adheision between the nickle and the mag material . you can peel it off quite easily.
as far as protective coatings go, there is another way, and that is to pre oxidise the surface. this is similar to gun blueing.
there is a product marketed under the name "extend" by loctite and "rust converter" from benjamin-moore.
these are paints that contain borium sulfate. it changes iron and iron oxide into iron sulfate.(smells like doggy doo when it's curing)
ive used it on antique trucks and it's very good for stoping corrosion.
i tried it yesterday on some peeling neos and they reacted the same way as the steel rotors.
i beleave i will use it as a primer and then coat my rotors with epoxy paint before casting the resin.
Re: Bad magnets (or bad design?) (3.00 / 0) (#40)
by Flux on Mon Sep 11th, 2006 at 02:24:13 AM MST
Stopping damage spreading on magnets is another issue, your goo may be effective or it may start a chain reaction, there is more in those magnets than iron and it is pretty unstable.
The stuff is quite good at stopping rust but I am not sure that epoxy will stick to it, you may be lucky.
Dan is probably right that the epoxy coating is better but you are almost certain to damage it. I agree that coating the whole thing with epoxy and a filler and making sure that nothing scratches the coating in use seems the most likely simple solution.
When you start looking into this you find that all magnets are not the same and some are far better than others. some have high oxygen inclusion that causes problems, some are nickel plated, some nickel copper nickel. some are electroplate and some electroless. Plating this material seems to be a nightmare.
It may well be that there is a lot of variation in the different sources of magnets and these may be from a different process than the ones Hugh has had no trouble with.
Re: Bad magnets (or bad design?) (3.00 / 0) (#45)
by alibro on Sat Oct 14th, 2006 at 02:20:51 PM MST
Hi Hugh
I have some rusted magnets but in my case caused by the stator crashing against the rotor. I started a new topic shown below and wondered if you intend to try to save your magnets and if so how, or will you just replace them.
http://www.fieldlines.com/story/2006/10/13/205511/74
Alister
  278 Scoop users have viewed this posting.
· http://www.scoraigwind.co.uk/n irvana
· Also by scoraigwind
