| Greetings all: I have a basic PMG generator to battery question. It has probably been covered before, but i could not find it- -so please forgive me if it has. A short simple answer is greatly appreciated.
I just made this small PMG alternator that does 10-20 watts max. at 300-500 rpm.(shown below) The magnets are tiny (3/8" diam x 1/2"deep) is why there is so little power. (live and learn) -The 20 watt max i get is while shorting it through my ammeter to get a reading. However, when I hook it to my 2/ 12V marine batteries (hooked parallel), I only can get 8 watts going in. Is it somehow possible to get the full 20 Watts going into the batteries. Unfortunetly, I cannot hook half the generator coils in parallel to get twice the amps, because it would take too strong a wind to reach cuttin voltage. (only getting about 10 volts @500rpm with coils hooked in parallel)
Is there anything I can do to get more of the maximum amps out of the 12 coils hooked in series?
I also have this same problem with a permenent magnet treadmill motor I was testing. I get 2or3 times the amps shorted thru my ammeter. -Any help is super appreciated.
This is my first PMG. Not much power but at least it works. It does 18vac/16vdc @500rpm and 13vdc(cut in) @300 rmp. |
