100/100/100 VAWT challenge
By Volvo farmer, Section Reviews
Posted on Wed Oct 24, 2007 at 12:13:54 AM MST
Put up or shut up
Here it is. The October '07 VAWT challenge from the farmer of Volvos.
Rules: 100 watts into batteries (12, 24,48V)  @ wind less than 20 mph. the turbine must survive  the elements and the wind, loaded, for 100 days. Homebrew only may apply, no commercial turbines accepted. Prize is $100 out of my own pocket. Must be vertical axis turbine. THERE IS NO SIZE LIMIT!
Only caveat is I need an outside observer to observe amps and volts so I don't get fleeced. If he can keep the hat on his head while measuring, I'll concede to 20 MPH winds.
I'd gladly pay to see this thing achieved. Sort of like the prize to get into space we've seen recently. I'm good for the c-note, ask DanB. Anyone want to add to the prize? this could get interesting!
100/100/100 VAWT challenge | 57 comments (57 topical)
Re: 100/100/100 VAWT challenge (3.00 / 0) (#1)
by healerenergy on Wed Oct 10, 2007 at 12:58:16 AM MST
I am not familiar with the October VAWT challenge and would like more info on it please.
When does it start?
When does it end?
Is there build time before this starts?
100 watt over what time frame.
Energy comes from many Sources the trick is knowing how to tap into it.
Re: 100/100/100 VAWT challenge (3.00 / 0) (#2)
by hiker on Wed Oct 10, 2007 at 02:14:38 AM MST
heres some free plans..
         http://www.picoturbine.com/projectlist.htm
WILD IN ALASKA
Re: 100/100/100 VAWT challenge (3.00 / 0) (#3)
by DamonHD on Wed Oct 10, 2007 at 02:24:25 AM MST
You want to get the VAWT into space too?  B^>
Re: 100/100/100 VAWT challenge (3.00 / 0) (#4)
by jacquesm on Wed Oct 10, 2007 at 05:09:17 AM MST
ok ,volvofarmer I'll add to the prize, $100 in the pot from me, and if you exceed 500 Watts for more than 1 minute another $100...
And for those that weren't here at the time I'd like to remind you of another prize that http://www.fieldlines.com/story/2004/9/19/143433/440 still hasn't been claimed...
Though I'd have to change the location because I've moved since then but otherwise the conditions are still the same.
www.greenbits.com
Re: 100/100/100 VAWT challenge (3.00 / 0) (#5)
by Stonebrain on Wed Oct 10, 2007 at 05:12:56 AM MST
This is really a cool proposition.
For building a rotor I need a few months.
I'm only not in building a decent alternator,a low rpm alternator is not what I'm after at the moment.I think this will be to expensive anyway.Can I participate if I can prove output without building an alt.Just with the dynamometer method?
Finding a person who can certificate the results and is thrusted by you might be a problem too.
cheers,
stonebrain
Re: 100/100/100 VAWT challenge (3.00 / 0) (#28)
by Volvo farmer on Wed Oct 10, 2007 at 09:30:17 PM MST
No vaporware allowed. Coils, magnets, swept area, volts, amps, watts... all allowed. If nobody wins in the timeframe, I'll likely extend the deadline.
Volvo Farmer
Re: 100/100/100 VAWT challenge (3.00 / 0) (#6)
by disaray1 on Wed Oct 10, 2007 at 06:56:37 AM MST
 I'd like to enter the contest and also raise the pot, but first, clarification on rules; Are you saying that it must produce (at least) 100w continuously for 100 days, or just verified 100w instantanious once per day?
 I live in a low wind area. Some rare days 5-10mph, and more often 2-4mph and not constant at all. It may take years to come up with 100 "good" wind days. See where I'm going? At what point and who will determine a winner?
 I'll add another $100 to the kitty "if" the whole thing is made from either found scrap or landfill bound material- all of it. Rotor, wire, magnets, bearings/hubs. Only thing that can be bought is hardware- nuts, bolts, washers and screws. Use your imagination. Wire can come from crt monitors, microwave transformers, or induction motor"unwinds". Magnets from hard drives, microwaves, old speakers etc. I'll make an exception for stator potting material, which can be purchased.
 Expect cheating. This is a contest with prize money. AND there are engineers involved. :-)
 David
Re: 100/100/100 VAWT challenge (3.00 / 0) (#7)
by DanB on Wed Oct 10, 2007 at 07:15:51 AM MST
I suppose Ed (windstuffnow) must be exempt...  he's actually achieved this I think.
Re: 100/100/100 VAWT challenge (3.00 / 0) (#8)
by richhagen on Wed Oct 10, 2007 at 08:37:25 AM MST
Jeepers, it would be like getting re-imbersed to build the thing. Not meaning to sound like a lawyer, but you would need to clarify and nail down the exact rules, start date, ect, or you'll have 20 people claiming they were first and wanting the prize money though. If its retroactive, Ed and others may claim the prize.  Rich
If the battery charging isn't clear, there's some folks in Iran whos ancestors built this that might put in a claim.  ;-)
All in fun, Rich
Re: 100/100/100 VAWT challenge (3.00 / 0) (#9)
by vawtman on Wed Oct 10, 2007 at 08:59:01 AM MST
The contest should be 2kw+
 That would be more of a challenge.
Re: 100/100/100 VAWT challenge (3.00 / 0) (#10)
by jacquesm on Wed Oct 10, 2007 at 09:16:30 AM MST
I agree, actually you'd probably qualify for the prize:
http://www.fieldlines.com/story/2007/8/25/20519/7542
I think the 100 watt for 100 days is challenge enough, especially if you consider that to charge the batts you're going to need quite a bit of RPM.
www.greenbits.com
Re: 100/100/100 VAWT challenge (3.00 / 0) (#11)
by fcfcfc on Wed Oct 10, 2007 at 12:25:27 PM MST
Cute....
Re: 100/100/100 VAWT challenge (3.00 / 0) (#12)
by Volvo farmer on Wed Oct 10, 2007 at 01:32:36 PM MST
Sorry about the lack of clarity.
The contest starts today and expires January 1 2008. If you've got something up and running by then, you qualify and the 100 days can start anytime before January 1.
I'd like to disqualify Ed or anyone else who has built one already if it doesn't hurt their feelings.
100W instantaneous, though I'd like to see it sustained for a short period of time, perhaps five minutes? If the wind doesn't blow for ninety days, it doesn't have to make any power on those days. It has to be set up in the weather and still be operable at the end of 100 days.
Pictures and or video will be needed to claim the prize, I get to pick the outside observer.
Volvo Farmer
Re: 100/100/100 VAWT challenge (3.00 / 0) (#14)
by windstuffnow on Wed Oct 10, 2007 at 02:00:55 PM MST
  Wow... didn't even get started and already I've been disqualified... guess I'll find a corner in my shop to sit an cry for awhile...
  All kidding aside, sounds like a fun challenge!  I certainly wish all you VAWT builders out there lots of luck.  It will be interesting to see some of the machines that come from it.  100 watts is actually pretty simple to accomplish from a VAWT, the biggest challenge I see is the alternator.
  Good luck to all and most of all have fun building it!
Have Fun! Windstuff Ed
Re: 100/100/100 VAWT challenge (3.00 / 0) (#15)
by vawtman on Wed Oct 10, 2007 at 03:09:03 PM MST
Hi Ed
 Ive been thinking of an idea for little vawts or hawts that charge batteries.
 What if you took a small motor(1/2hp) with 36 slots and did this,
 Rotor leave stock but drill in many holes for small neo rods in the cage bars and set it up for 12pl.
 Stator remove the windings(some motors arent varnished)and rewind for 12pl.Maybe able to use the stripped wire if carefull.
 You could direct drive it and without the machining.
 Little bitty neos are cheap.
 Thoughts.
Re: 100/100/100 VAWT challenge (3.00 / 0) (#16)
by wdyasq on Wed Oct 10, 2007 at 04:58:05 PM MST
Editor - Is this what one calls thread hijacking?
Just curious,
Re: 100/100/100 VAWT challenge (3.00 / 0) (#19)
by TomW on Wed Oct 10, 2007 at 05:03:41 PM MST
Yes.
Death or just a beating is the question?
T
Re: 100/100/100 VAWT challenge (3.00 / 0) (#21)
by vawtman on Wed Oct 10, 2007 at 06:28:46 PM MST
Can i have my last words before i die?
Re: 100/100/100 VAWT challenge (3.00 / 0) (#17)
by richhagen on Wed Oct 10, 2007 at 05:01:49 PM MST
Actually Ed, you've already won, in a way, because you have built funtional machines along these lines, which I recall being an interesting read.  Rich
Re: 100/100/100 VAWT challenge (3.00 / 0) (#20)
by windstuffnow on Wed Oct 10, 2007 at 05:13:55 PM MST
  I have one flying that does around 140 watts in a 20mph wind.  I wouldn't have enter'd it anyway, I'm more interested in everyone elses machines.  I get more enjoyment watching the creativity than trying to compete.
Re: 100/100/100 VAWT challenge (3.00 / 0) (#22)
by CmeBREW on Wed Oct 10, 2007 at 06:41:52 PM MST
ED:  It's EASY to be MODEST when you've ALREADY won!!! (He,he)
YOU may think it's easy, but I don't think its easy to get 100 watts at 20mph! I doubt now mine latest will do it. I really believe it WILL hit 100 at some point, I just hope it don't take off like a rocket and land somewhere in Texas when it finally does!.
Yes, I think this contest is a good interesting idea, and I hope many will partisapate. But I really think we all need more time.
The rules are still not perfectly defined. Can someone simply do a COPY of the LENZ2 or simply make a LENZ2 with bigger blades?? I wonder if that should be allowed since everyone knows you've already accomplished it.
Making a design that can withstand the INSAIN weather is the most difficult thing I think. Perhaps everyone here should pick the winner. I like it!
Re: 100/100/100 VAWT challenge (3.00 / 0) (#18)
by MaryAlana on Wed Oct 10, 2007 at 05:02:17 PM MST
Wish I had the time and the extra $$$ to do this. Just went through a week of 25mph+ winds :-)
Re: 100/100/100 VAWT challenge (3.00 / 0) (#24)
by gizmo on Wed Oct 10, 2007 at 08:50:40 PM MST
I dont understand this, is there a point. Why on earth is Ed not allowed in the race. Its like someone is trying to say the VAWT's are no good for making power, and to prove it we are having a competition. Only thing is the people who have proven VAWT's do make power are not allowed to play!
I say anyone should be able to play. If Ed or anyone can fire up a old VAWT that makes 100 watts then they are the winner. I've seen a big 4 layer oil drum windmill
driving a truck alternator, its making over 100 watts! Can he claim the prize.
Need to define the rules, frontal area should be a consideration, as what you are trying to say is a VAWT cant make the power of a HAWT of the same size.
Otherwise some people are going to loose their hard earned money.
Glenn
http://www.thebackshed.com
Re: 100/100/100 VAWT challenge (3.00 / 0) (#26)
by Volvo farmer on Wed Oct 10, 2007 at 09:24:42 PM MST
Okay, would you be happy if I gave Ed $100 for already winning, and then give $100 to the next guy who can do it? Maybe I should have changed it to 200W so that he can compete too?
Yes, the oil drum guy can claim the prize. Have him post in this forum with pictures and give me his location so I can find somebody to go look at it to verify and if it's still up and running in January, I'll pay him.
To be honest, I bet I worked less hard at earning this $100 than someone is going to work to earn it.
Here's my point... if you really don't understand it. If I had posted a challenge to make 600W in a 20MPH wind with a HAWT, There'd be a dozen guys all over it, because it's being done, every day, in scores of locations all over the world. I'm challenging people to make 1/6 that amount of power with a VAWT, because I think it is a inherently inefficient way to make power, and 100W ain't easy to make. I've heard of exactly one guy doing it here.
You can cry about my rules or you can get to work building your turbine. Make your own contest if you don't like mine.
Volvo Farmer
Re: 100/100/100 VAWT challenge (3.00 / 0) (#29)
by gizmo on Wed Oct 10, 2007 at 10:05:16 PM MST
Oh dont get me wrong, I do like the idea, but just want to see the rules better defined. Maybe a bet of $100 is asking for trouble, why not just a contest to see who gets the best results for said frontal area. Restricting frontal area will mean only the most efficient of VAWT's stand a chance. There are a lot of VAWT's out there with no alternator attached, it will be good to see these projects finished and the real figures to come through. 100 watts is a good size, its bigger than "toy" size and means the builder needs to overcome the VAWT problems like bearings and wobble for the thing to stay together.
A F&P will be a good alternator if you can get one, I built a small Lenz2 on a F&P and it started charging into 12 volts at only 20 RPM, direct drive.
Glenn
Re: 100/100/100 VAWT challenge (3.00 / 0) (#13)
by Slingshot on Wed Oct 10, 2007 at 01:49:04 PM MST
If the wind isn't cooperative while the observer is available, can the VAWT be put on a truck and run down the road (average of 2-way pass to minimize breeze effect) at 19 MPH?
Re: 100/100/100 VAWT challenge (3.00 / 0) (#27)
by Volvo farmer on Wed Oct 10, 2007 at 09:26:30 PM MST
Sure, I'll accept that.
Volvo Farmer
Re: 100/100/100 VAWT challenge (3.00 / 0) (#43)
by finnsawyer on Fri Oct 12, 2007 at 09:08:28 AM MST
"Sure, I'll accept that."
Oh,oh, you could come to regret that.  If they place the VAWT on the back of a flat bed truck it could benefit from the speed up of the air coming off of the cab.  You might want to reconsider.
GeoM
Re: 100/100/100 VAWT challenge (3.00 / 0) (#23)
by powerbuoy on Wed Oct 10, 2007 at 07:58:00 PM MST
Volvo:
What will you do in case there might be 50 people showing up with working designs ... ???
You must have deep pockets :-)
Powerbuoy
Re: 100/100/100 VAWT challenge (3.00 / 0) (#25)
by Volvo farmer on Wed Oct 10, 2007 at 09:07:57 PM MST
Whoops.
Uh my intention was only to be out a hundred bucks, and maybe not even that so I guess it's a race. First one to make 100W instantaneous and last 100 days wins.
Volvo Farmer
Re: 100/100/100 VAWT challenge (3.00 / 0) (#30)
by Off grid in Tonopah on Wed Oct 10, 2007 at 10:23:01 PM MST
Since there seems to be so many variables why not have the contest run thru the year. Threshold to compete is as you laid out. At the end of the year let the board vote on the winning machine. Most votes wins. Judgment attributes could be ease of construction, simplicity of design, most innovative design, use of materials, most common materials, highest efficiency things like that. This way everyone can play, some folks may want to collaborate and form build teams. Kind of like turbine wars. Some build better more efficient generators than others while some have a knack for turbine design. Bottom line is after a year this board should be able to take the best of the workmanship, knowledge and creativity that resides here and put out a dame good turbine design or two. Just my two cents.
                                               Bob
Re: 100/100/100 VAWT challenge (3.00 / 0) (#31)
by Volvo farmer on Wed Oct 10, 2007 at 10:59:29 PM MST
I predict there will be NO winner. It's my C-note, it's my challenge. Sorry if this sounds harsh, but either build a turbine and collect the prize, or put up your own money for your own contest, and define the rules as you see fit. Maybe I'll extend the deadline if there is no winner.
Maybe I wasn't clear enough at first but I think its getting narrowed down now. 100W instantaneous, 100 days in the elements, 100 bucks. Pictures and Fieldlines forum posting necessary. First successful entry wins.
I'm about done here in this thread. Thanks to those who pointed out unclear parts of my challenge. If I'm still unclear, I'll post back and try and crystallize terms.
Volvo Farmer
Re: 100/100/100 VAWT challenge (3.00 / 0) (#40)
by Phil Timmons on Thu Oct 11, 2007 at 04:33:11 PM MST
You might be right . . .  but do not forget the upper bounds -- if ten guys did this, you would be out $1000.  on and on.
Might want to put a cap on this.
Re: 100/100/100 VAWT challenge (3.00 / 0) (#32)
by wooferhound on Thu Oct 11, 2007 at 01:03:19 AM MST
And we need to get the Discovery Channel in on it too . . .
W o o f -={(
Re: 100/100/100 VAWT challenge (3.00 / 0) (#33)
by thefinis on Thu Oct 11, 2007 at 05:31:40 AM MST
Well Volvo you know how it goes here. Post all the details, be specific, list the variables, list your goals, expect us to pick at what you posted.
I like the idea but think it should have been refined more on the rules but it is VF's baby. I doubt that I'll bother as my newest time line is rather slow(got a 2nd job and building a tower right now) and I am using Ed's design on blades so I would have to share and a mere C note would not even cover gas money already spent to get parts.
I am not trying to hijack VF's contest or thread so to some extent this offer hinges on his willingness to include it. If the contest gets going and there is much interest(5 or more entries) I would consider kicking in a second prize of a $100 US to the one who builds the most watts per sq yard or sq meter(they are close we can come up with a fudge factor) if you are willing to let others copy the design and we can come up with a good way to determine the efficiency. This helps even out the field so just sheer size does not get all the money. Any body got a way that would make this fair and easy to figure? I kind of think it would need the wind speed or a close estimate to help figure efficiency. Maybe for those with no anemometer a time and date of test with the noaa wind data for their area on that date. I would be willing to give this to Ed or anyone else and consider it the best $100 for research I have spent so far.
Carry on
Finis
Texas born and bred
Re: 100/100/100 VAWT challenge (3.00 / 0) (#34)
by coldspot on Thu Oct 11, 2007 at 06:20:14 AM MST
I have to ask-
Does a "Jumbo" type count as a VAWT??
$0.02
Re: 100/100/100 VAWT challenge (3.00 / 0) (#35)
by dinges on Thu Oct 11, 2007 at 06:54:59 AM MST
Do I hear this right ? Not -one- single contestant so far?
Too bad Ron told me that if I were to enter the contest and build a VAWT we wouldn't be friends anymore, otherwise I'd enter into the endeavour. I really value his friendship, you know.
Peter.
Re: 100/100/100 VAWT challenge (3.00 / 0) (#36)
by DamonHD on Thu Oct 11, 2007 at 06:58:16 AM MST
Well, I'm on the wrong side of the pond for a visit, and I'm not tooled up to even build and test my real 'VAWT' yet.  Plus, being the first time, I'll make a horrible mess of it I'm sure!
I'd hope to enter a later re-run of this competition, though possibly in an "urban-we-dont-get-steady-winds-round-here" class...
Re: 100/100/100 VAWT challenge (3.00 / 0) (#37)
by DamonHD on Thu Oct 11, 2007 at 06:59:16 AM MST
Oh yes, with the 'zoning/planning-laws-wont-allow-a-tower' rider too!
Re: 100/100/100 VAWT challenge (3.00 / 0) (#39)
by disaray1 on Thu Oct 11, 2007 at 07:54:45 AM MST
Peter said...
  "Do I hear this right ? Not -one- single contestant so far?"
 Reread 7th post.I'm in, so maybe I'm the lone sucker?. Possible 400 clams for the winner.
  You could always create another identity so Ron wouldn't know it was you, build a vawt, stomp the competition, collect the money and buy some flowers or candy for him and he'd never know a thing and your relationship would be even stronger. ;)
 David
Re: 100/100/100 VAWT challenge (3.00 / 0) (#38)
by wdyasq on Thu Oct 11, 2007 at 07:53:17 AM MST
Mr. Farmer of Volvos,
Thank you for offering this fine challenge. I fear not for those who attempt the challenge, but the poor soul who has to verify it. Although the possibility of injury due to the machine self destructing may not be large, it is there. And, there are the expenses that will be incurred.
In light of this, I am offering one of the images of a dead United States politician with the $20 symbol next to it to the 'observer' you appoint. This is a one time offer and the selection of the observer is yours and yours alone.
I realize that it is not much compensation but, it is not much of a job and the observer should have a good time anyway. However, the observer need not be punished (too bad) just because he is the one selected to venture and verify the unbelievable.
Sincerely,
Re: 100/100/100 VAWT challenge (3.00 / 0) (#41)
by ghurd on Thu Oct 11, 2007 at 05:41:49 PM MST
I don't understand why so many people are confused.
Maybe Charles Lindbergh won a prize, but all the passengers on a trans-Atlantic flight scheduled for tomorrow don't get the same prize money.
Maybe we all should submit Bjørnstjerne Bjørnson's 1903 Literary work and claim we are entitled to the same Nobel prize?
Ghurd.info
Re: 100/100/100 VAWT challenge (3.00 / 0) (#42)
by Spdlmt150 on Thu Oct 11, 2007 at 10:33:04 PM MST
Just a thought I've had.... Could this be an array of vawt's, or does it have to be a single unit?
Re: 100/100/100 VAWT challenge (3.00 / 0) (#44)
by motoman465 on Tue Oct 16, 2007 at 10:05:45 PM MST
I'll throw my hat in the building ring.  If I am lucky, I might learn someting along the way!  Sounds like fun!  Thanks, Volvo Farmer.
Todd
Re: 100/100/100 VAWT challenge (3.00 / 0) (#45)
by feral air on Thu Oct 18, 2007 at 05:45:57 PM MST
"the turbine must survive  the elements and the wind, loaded, for 100 days."
Practically impossible to prove. A cheater could snap a bunch of pics over a couple days from different angles and bring the turbine in and then post a pic a day to "prove" that it's still outside. Before the observer shows up they could set it back up.
The 100 days part is kind of silly anyway. If you're gonna go through the trouble and spend the money to do it of course it's going to last 100 days.
"THERE IS NO SIZE LIMIT!"
Then there's no reason it can't be done then, the only challenging part is the time limit. And for those of us that can't build for squat it's still practically impossible...not that it would be any easier for us to build a hawt.
"Only caveat is I need an outside observer to observe amps and volts so I don't get fleeced. If he can keep the hat on his head while measuring, I'll concede to 20 MPH winds."
I think you're setting yourself up here. Just because a lot of people put their vawts at ground level or not much higher doesn't mean everyone does/will. Does it still count as 20mph if the observer's hat doesn't leave his/her head and the 'mill is 60ft up?
The biggest part I have a problem with is the battery requirement. The prize doesn't even cover the cost of the battery so it's not as cool as it sounds at first blush. If you didn't require that (or sent one with the observer) then you're talkin'...then there's at least some chance of the winner breaking even or coming close, if there's a winner.
Not a bad idea overall (and really pretty cool to put up a prize!) but I think it could've been planned better and the date set a little farther out. I don't even want to imagine how fun it's going to be to get an observer out to several different places scattered all over...I don't envy you. ;-) take it easy
Re: 100/100/100 VAWT challenge (3.00 / 0) (#46)
by wdyasq on Fri Oct 19, 2007 at 06:26:25 AM MST
feral,
One of the neat things about America and this contest is - nobody is holding a gun to your head and forcing you to do this. Another neat thing is you are allowed to complain  even if you don't play.
I think the Farmer has given a more than fair contest and I am looking forward to paying my $20 to the observer ....... IF anyone ever builds one.
That is a third great thing about America. Everyone is allowed to spout and spew about what they are going to do and they aren't required to back it up. Volvo Farmer just gave them the reason to post their results of the VAWT rather than just talk about what 'can be done'. Now, a couple of hundred bucks won't buy the materials to construct a wind machine and test it, it will offset a bit of the costs if one is successful.
Hopefully this contest will do one of two things, advance the science of the VAWT or silence those who claim it can be done. Maybe, it will do both. Or, I may get to keep my $20.
Re: 100/100/100 VAWT challenge (3.00 / 0) (#47)
by boB on Tue Oct 23, 2007 at 07:43:50 PM MST
VF, I think you better refine the rules once more.
One could accomplish this with LESS than 20 MPH, by simply accumulating energy and then, when stored  over a few hours, wind blowing or not, dump that into the test battery at 100+ Watts for 5 minutes.  Accumulate some more energy and do it again the next day.
You'd have 24 hours to store  100 W X 5 minutes = 8.33 Watt-hours, minus losses of course.
THAT could be done fairly easily at way less than 20 MPH  I would think.
boB
Re: 100/100/100 VAWT challenge (3.00 / 0) (#48)
by Volvo farmer on Tue Oct 23, 2007 at 08:57:16 PM MST
LOL
Okay for this competition, no fair storing up energy in anything then dumping into a battery. However, I will pay fifty bucks to anyone who can do what you described with a VAWT... Before the end of the year.
You're not eligible since I need you to build me a better charge controller. Get back to work ;-)
Volvo Farmer
Re: 100/100/100 VAWT challenge (3.00 / 0) (#49)
by boB on Tue Oct 23, 2007 at 11:17:55 PM MST
OK... OK....  Just as soon as I finish my cigarette !
Re: 100/100/100 VAWT challenge (3.00 / 0) (#50)
by disaray1 on Wed Oct 24, 2007 at 06:27:15 AM MST
Jeeez, boB.
  Thanks for goofing my plan to liberate Volvo of the cash. Why do you think I asked specifically about output continuous/instantaneous? I've been collecting caps for weeks.
 NO CHANGING THE RULES DURING THE GAME!
 David
Re: 100/100/100 VAWT challenge (3.00 / 0) (#51)
by Volvo farmer on Wed Oct 24, 2007 at 08:46:37 AM MST
I see no winky faces or smiley faces. So I assume you're really crying about this? I think the intention of the contest is clear, if people want to go around my intentions so they can have a Ben Franklin and say they out-smarted me, fine.
Build it with caps and I'll pay you. Somebody build something quick so I can pay them and be done with this soap opera.
Volvo Farmer
Re: 100/100/100 VAWT challenge (3.00 / 0) (#52)
by disaray1 on Wed Oct 24, 2007 at 10:17:37 AM MST
Naah Volvo...I was really just goofing with boB and forgot the smiley face- Although I was considering exactly was he thinking, since the rules were so vague. I spent many years of my life taking carefully crafted rules and going around them, by either interpreting them differently than intended, or just by out and out cheating. That's the way professional motorsports works. And I absolutly love "put up or shut up". Truly, the money is not important to me, the challenge is what I was going for. And challenging it is... BTW, I'm not in the "vawt camp"...hell, I dont have a camp, but I generally always root for the underdog. Sometimes they do win and those victorys are oh so sweet.
 I think the challenge you presented is interesting and a good thing here, even though I understand the flavor of the original post (I wasnt offended, but I think a few may have been). Regardless, even if one person walks away with some knowledge and a better understanding of the difficulties involved in electricity generation via vawt, it was worthwhile, IMHO.
 I wont do the caps....but with 68 days left, I've still got some time to scheme. :-P
 What soap opera?
 David
Re: 100/100/100 VAWT challenge (3.00 / 0) (#53)
by DamonHD on Wed Oct 24, 2007 at 10:41:28 AM MST
I'm not in the running for this competition, but I'm definitely motivated by it!
Re: 100/100/100 VAWT challenge (3.00 / 0) (#54)
by bob golding on Wed Oct 24, 2007 at 04:55:37 PM MST
does it have be a novel design or can i enter one based on ed,s design?
cheers
bob golding
Re: 100/100/100 VAWT challenge (3.00 / 0) (#55)
by thefinis on Wed Oct 24, 2007 at 05:43:26 PM MST
Seems to me that almost any design is based somewhat on someone else's design. I did not see any where that it said it needed to be an original design. Mine is based on Ed's but I have money up for the most efficient and I will not try for V Farmer's money cause I can not keep one up and loaded for that long. Heck usually 2 or 3 weeks and I have them down for the next change.
Dang it wish my load of sucker rods would get here so I could finish my tower.
Finis
Texas born and bred
Re: 100/100/100 VAWT challenge (3.00 / 0) (#56)
by Volvo farmer on Wed Oct 24, 2007 at 06:54:19 PM MST
Of course you can enter one based on Ed's design, or anyone else's for that matter. Will you? That is the question. :-)
Volvo Farmer
Re: 100/100/100 VAWT challenge (3.00 / 0) (#57)
by coldspot on Tue Oct 30, 2007 at 08:27:09 PM MST
V F-
"I have to ask-
$0.02"
I am still wondering about this question?
Could I enter a "Jumbo" type?
(the maybe barrel halfs blades sideways to the ground, with a sheild from the wind when moving into the wind comes around)
{the type I'd like to play with soon}
Anyway great challenge for us all, so thanks!!
  397 Scoop users have viewed this posting.
· Also by Volvo farmer
