| Well, I visited various local DIY/tool shops today, and now have nearly a grown-up haul of G-clamps, mallets, roofing bolts, etc.
The first thing I did was make a bearing for my PM gen so that I could build the rotor on top for a VAWT configuration. Cunning use of a plank of wood, 2 G-clamps, and two angle brackets to grasp the flat on the PM gen shaft, etc. It may not last but it is reasonably sturdy for experimental purposes and government work... B^>
This also for the first time allowed me to test when I might get cut-in to charge a 12V battery, using my analogue multimeter on 'AC Volts' across one pair of the delta-wired outputs. My guess is at about 120rpm, which is probably just about do-able.
Then I attached my biggest-available box (from my scanner) to the PM gen, and cut the slots as for my smaller cereal-box rotor.
Then we put it out to face the wind, but so far, nada!
I'll put a little write-up with pics on my site later, if anyone is interested.
Damon |
157 Scoop users have viewed this posting.
