With my 20' wind turbine down I felt inspired to finish the project of building a direct drive battery charging alternator for the 'FuKing' Listeroid diesel engine. For the last few years we've used it as a backup generator and it's been belted to a 5KW 3600 rpm WinCo alternator head. There is a page about that here. This arrangement worked pretty well - we could run the welder of the 240VAC end of the alternator, or charge batteries with the 120VAC. Trouble is - it's just not that powerful. To charge batteries I would run the output of the winco generator into my Trace 4048 inverter, which worked well - but over about 1.5KW it would slow the engine enough so that the inverter would reject the output of the generator - and -while charging everything was actually running off the generator, so if did so much as turn on the bandsaw (or any other large load) -it would slow the generator and the inverter would kick it off line. So basically - if I had low batteries and charged with the generator we couldn't use much power at the same time.
Last spring I installed an autotransformer so I could take 240VAC off my inverter, and I've learned that my well pump and my welder (the only things that need 240VAC around here) run much better off the inverter than they do off the generator. So we decided to build an alternator for the listeroid that's dedicated to charging the batteries.
The alternator is basically identical to the ones we build for 10' wind turbines. Just like the steam engine project I turned out a wheel hub to fit the shaft of the engine.
The magnet rotors are 12" diameter each with 12 2" dia x 1/2" thick N40 grade NdFeB magnets. We banded them with stainless steel and cast vinyl ester around them.
There is the engine with one magnet rotor mounted on the shaft.
We built a 'stator bracket' out of angle iron that bolts to the engine where the fuel tank used to bolt on. The stator has 9 coils, wired in star. Each coil has 28 turns of wire - we wound with 4 strands of #15 gage wire.
There it is all finished up!
A veiw from the side...
It pretty much works as I had expected. 650 rpm (the rated speed for this engine) gets us right at 2KW give or take a bit depending on battery voltage. It gets a bit warm to the touch but certainly not anywhere near 'hot'. It's very efficient. It's also much easier to start the engine now that the belt is gone. I'll leave the old generator on there and keep the belt for 'backup' but as it is now it's much more efficient and a much more practical generator.
The 'otherpower.com' engine room..... (or at least it will be soon when we get a roof over it!) |
225 Scoop users have viewed this posting.
