All summer long I've been working on a swing
glider finally decided to get plans and restarted
It's been my thoughts to run numerous things
with the power of a pendulum and sufficient weight
( 200 lbs of me on a glider swing....keeps gradually
getting less.....but that's another story)
Here's a picture of it converting linear motion
to rotary motion.....
Okay...now the orange board is connected to the
back of the swing seat by a hinge, the other end
of the board is connected to the green board also
by a hinge, bottom of green board to base also
a hinge.
Right about in the middle of the board a 3/8
hole is drilled, the end of the chain is passed
thru the hole and a farmers pin (nail) is
dropped between a couple of links...the chain
goes over a choice of 5 sprockets (5 speeds)
around and under and later on a bungee cord that
passes thru a hole and attached somewhere....
As the swing goes to the right it moves the
green board to the right pulling the chain and
turning the bike wheel clockwise, when the swing
goes to the left .....return stroke, the bungee
cord takes up the slack and the sprockets turn
counter-clockwise and ratchets,
and so that's the whole swinging action....I'll
update this and go into more detail as I hook it
up to the Ametek 30volt.
Just a whole bunch of fun !
( :>) Norm. |
151 Scoop users have viewed this posting.
