| ...often go amiss (or somethin' like that, anyhoo
yesterday i hada remove the blowout panels from the helix due to noises they were making, so it was back up on the ladder for a while (cold fingers, again!)
sure eneough, the noise seemed to go away.
hour or so later i heard a new noise (helix was spinnin' without any load on it)
every time the rpm went up and down (gusty winds) noises again ...just different ones.
looked like the bottom heavy duty floating bearings' grease was stiffing up as it got colder...sprayed in a bunch of lube to thin the grease a bit....once again the unit quieted down...
woke up this am to hear NOISE again, winds were a lot stronger 25-35mph and it was somewhere near zero wind chill; locked the helix down in the dark
judging from the sounds the noise is internal, ie from inside the helix structure
thinkin now that it might be spring before i can safetly fix/replace whatever is wrong
will know more when it is lighter outside
spinner
Resectioned. Good luck with it. |
145 Scoop users have viewed this posting.
