1981 National Geographic
By Goose, Section Diaries
Posted on Sat Dec 22, 2007 at 04:08:37 AM MST
Energy Crisis
Found this digging around the other day.  It was a special edition from 1981.  Interesting what they were saying back in the early 80's.  Most of the same problems as we see now.
I would like to post some of the articles, but to be able to read them, they are just too big.
<BR
1981 National Geographic | 6 comments (6 topical)
Re: 1981 National Geographic (3.00 / 0) (#1)
by terry5732 on Fri Dec 21, 2007 at 11:50:33 PM MST
Waterford crystal is worth less than it was then. It's mostly made in Poland now.
Re: 1981 National Geographic (3.00 / 0) (#2)
by windy on Fri Dec 28, 2007 at 08:39:50 PM MST
 When seeing articules about energy conservation and global warming, some things never seem to change. In the 80's when I had my Dodge Charger hatchback with a four cylinder engine, I could easily get 36 to 40 miles per gallon. Now, all the car companys want me to buy a car that costs 10 times more than my first car and get an incredible 28 miles per gallon. Go figure!
windy
Re: 1981 National Geographic (3.00 / 0) (#3)
by Gordy on Sat Dec 29, 2007 at 11:10:04 PM MST
Literature for the 63 Ford Falcon claimed 32+ mpg. With a 140 cid 6cyl.
80's VW Rabbits & Ford Escort's with diesel engines were getting 50 & 55 mpg.
My 89 Mazda MX6 gets 32 mpg.
So I agree why can't they do better now ???
Gordy
Re: 1981 National Geographic (3.00 / 0) (#4)
by elvin1949 on Sat Dec 29, 2007 at 11:53:50 PM MST
 My 89 Ford Festiva with auto [3 speed no overdrive]
got 40 mpg.My brother's 90 festiva with 5 speed manual overdrive tranny got 53 mpg.
 Both had a/c.
Elvin
Re: 1981 National Geographic (3.00 / 0) (#5)
by joestue on Sun Dec 30, 2007 at 01:23:11 AM MST
Emission control is to blame.
I can't post a source, but someone said new cars cycle the engines rich and lean every few seconds to give the catalytic converter enough oxygen.
Today's catalytic converters also increase the exhaust pressure significantly more.
my 1990 toyota pickup gets 22 MPG, at 258 thousand miles, and has no torque left.
And of course the automatic transmission is your friend!
Re: 1981 National Geographic (3.00 / 0) (#6)
by spinningmagnets on Sun Dec 30, 2007 at 11:08:55 AM MST
I owned a manual trans Ford Festiva for a couple of years. I got a consistent 45 MPG without even trying. I was suprised at how perky the acceleration was, but if you had a second person in the car you could really feel the drag. The top speed was about 75 on level ground with one person, so gearing was low to help the tiny engine. After digging some, I found it was a re-badged Kia from South Korea, and I was impressed with its reliability.
In 2008 or 09 diesel cars will be more available in the US. Most manufacturers were not interested in having a diesel option when their are 5 important states (California is a big market by itself) where the old style diesel didn't meet the newer European clean diesel standard because USA diesel fuel had high levels of sulfur.
You could buy a diesel VW or Mercedes in Arizona, but you had to put 7,000 miles on it before you could "move" to California and register it there. (Cordless drill on the odometer cable?).
Sulfur acts as a lubricant, and when removing it (in 2006-7) refiners had to add something to replace it, and the government ramped up bio-diesel production with incentives, so bio-diesel is added at about 5% as a fuel pump lube. All USA diesel fuel in 2008 meets the new clean diesel standard.
Current diesel engines have more excursions into a rich and lean condition when RPM's cycle than gasoline engines. When rich, the new exhaust has a soot trap. When lean, some low-oxygen exhaust gasses are bled into the intake (Exhaust Gas Recirculation-EGR). To reduce cylinder heat (and thus NOX production), the new diesel EGR (unlike gasoline EGR) is cooled.
Rather than have an old-style mechanical fuel distributor (at 18,000 PSI), the new clean diesels have electronically controlled fuel injection. Because of how thick diesel is, the newer diesels use 30,000 PSI for finer atomization, and a cleaner burn.
All new cars need to meet the new front-and-side impact standards (heavier, more expensive), and the tiny cars that are available in the USA have a more powerful engine and a higher final drive gear ratio than the old Festiva. This improves the two-person top speed, but lowers the one-person mileage. The VW diesel Lupo gets ~80 MPG, but doesn't meet the new USA crash standards. It probably also would NOT be enjoyable to try and cross mountainous Colorado in a Lupo with three people in it, but it is selling in Europe ($5-$6/gal).
Companies will only survive if they produce what the consumers are buying, so we must blame all of us for some of this.
My wife is resistant to us getting one of the 80's VW/Mercedes diesels (but she doesn't mind me building an electric bike). My community won't allow me to have a windmill or a clothes drying line. (A single tear slowly rolls down Rons cheek as the camera close-up captures the sadness and frustration in his eyes...)
"We don't like their sound, and guitar music is on the way out." - Decca Records memo, rejecting the Beatles, 1962.
  122 Scoop users have viewed this posting.
· Goose's Diary
