Hi All
Im working on a Lenz2. The wingspan is 3 meters tall, 1 meter in diameter. That should poss. produce ~ 340 watt 8 m/s at 120 rpm (If Ed Lenz is right - im sure he is!). I want to build a directdriven alternator and this is offcourse the troubleling part. I know that this is not an optimal solution and many thinks it would be better to gear the alternator, but I want to give it a try.
I read throug the whole board (or so it feels), but havent found any descriptions of a low rpm alternator for small turbines. It seems like the main problem for the VAWT now (after Ed cracket the main upstickle) is making a low rpm alternator match the turbine.
Alternator goals:
- cut-in 5 m/s - 75 rpm
- most effective at 8 m/s - 120 rpm - 340 watt
- cuts out at 15 m/s - 230 rpm - ~ 700 watts or more
IF an alternator was to be made for this Lenz2, without regard of price of magnets, what would it look like(specs)?
Regards
Mikkel - Gotland, sweden. |
136 Scoop users have viewed this posting.
