| In the last few months I've been building a back-up power system. The system evolves in my mind as I work on it, so it's a moving target to some extent. The original idea was a smallish (1 KWH) battery setup plus a medium inverter, charged from the grid. I was just hoping to run a small freezer and a couple of lights for a limited time in case of power outage. By now it's evolved into a 5KWH (nominal) battery bank (12V 450 AH - 4x golf-cart size Rolls), a sizable inverter/charger (used Prosine 2.0), 360W peak PV (2x SunElec 180), MPPT charge controller (blem BZ), etc. Now thinking of adding another small chest freezer in the cool basement, configured with an external thermostat to run as a very low-energy refrigerator. I've run some AC cabling from the inverter output to 2 outlets, one central in the house, one out in the mud room. Also some 12VDC outlets.
Here are a few photos of my homebrew electrical panel for the system. It's now complete except for the PV feed cables, which will attach to the charge controller in the upper right corner. The second charge controller under the main one is for auxillary PV panels if I ever feel the need to set then up in the yard if I'm desparate for every last bit of juice - I have the HF 45W set stored as a spare... The DC (and AC) protection is all breakers. The AC sockets on the left are the grid input, the inverter/charger AC input (orange plug, NEMA 20A plug to prevent plugging the inverter into its own output) is seen plugged into an adapter to 15A plug for connecting to a generator if needed. Batteries are in a plastic storage container (with flat bottom, hard to find). Vent pipe has a small fan in the top end (exhaust), the circuit to turn it on when the batteries hit about 13.8V hides in the switchbox at the top (to the left of the charge controller) - the switch is for manual operation of the fan for the purpose of airing out the basement.
160 Scoop users have viewed this posting.
