see, no air bubbles. I used ATH and vinyl ester for these.
I wound the stator up using 29 turns of # 14 wire. Its wound 4 in hand. Its wound for 48v but I have a 24v system. I might be changing out inverters soon and I wanted something I could use in the future. 1500 watts was an acceptable amount of power for me, so I figured I would try an MPPT controller and buck down to where I needed the final output voltage. This makes the stator super efficient. more about this later.
Used brass lugs on this one. ran out of crimps that fit 4 #14 wires. This worked. 2 in each hole.
Its ready to be cast.
Mixed up some vinyl ester and ATH.
Heres how it came out. Pretty nice. Im holding it on with some magnets so I can get the dimentions for the stator mounting bolts and the brackets I have to weld on. Making sure everything is centered pretty well.
Here it is all mounted.
Here you can see the radiator that will eventually be run to the shop with insulated lines. I just hung it up for now. The alternator hums slightly when its running, you can just pick it out if you listen carefully.
Im bringing in the power 3 phase wye (similar voltage to DanB (he has a 48 v system). It enters the 3 phase rectifier on top. it exits pulsating DC. It is then filtered (to get the ripple out) by 6 electrolytics. 4200uF @ 350v limit (I just had these handy). The voltage were seeing is around 62 volts @ 600 rpm. The MX60 is to the right. I have LOTS of playing to do with this. Im attempting to mess with the programming a little. Im pretty sure it does good as it is with alot of the PV settings still in there.
Maxing out the MX60, it runs most happy below 650rpm. Here I have it turned down to 604rpm. Ive had it as low as 380rpm and it still worked but it isnt as efficient and puts more stress on the cotroller because the voltage isnt as high at this low RPM. Like I said, lots of playing to do. It will be interesting to see the fuel usage comparisons with DanB maybe :-) The alternator is pretty powerful and I have a feeling it will do better than 2kW, but unfortunately is limited by the 60A the MX60 will pass. If I convert to 48v, Im sure it will do better than 2kW.
more later.
Have Fun!!!
Roy R
Roy, had to remove the " and replace with inch to avoid the 50 word limit in title bug that prevents replies if you use punctuation in the title in both posts. Nice looking stuff, too.
290 Scoop users have viewed this posting.
