I write this with some trepidation, no-one like to be told they've got it wrong.
I've read LOTS. The trouble is, the more I read now, the more confused I become, and I'm beginning to get cold feet.
The idea was to build a small turbine, no more than 4' diameter blades. The plan is for a dual rotor with the usual 12 pole 9 coils. I have 24 1 inch diameter neos which are n42 and 1/2" thick.
I've made the rotor mount that is going to hold my 6mm thick discs, the airgap will be 12mm at the moment.
My rotor discs are 210mm diameter, and I'm planning on the magnets (centres) sitting at around the 75mm radius.
I'm not sure on the coils, but I think these will be 1.6mm wire (16swg which is close to 14 awg) and around 40 turns. If I can get away with a lower
diameter, that would be nice. The way I've drawn it at the moment means that the coil hole is slightly larger than the magnet diameter to get the correct spacing and coverage of the magnet by the coils, and this is what is starting to worry me. |
88 Scoop users have viewed this posting.
